A little sub build - Car Audio Classifieds!
Old 05-07-2012, 10:55 PM
Dunbar91's Avatar
0/11 sssss6816
Feedback Score: 51 reviews
Default A little sub build
So i have a bunch of RF P3 motors and one day i decided to build a 12" and it suprised the hell out of me and sounded amazing off of 800rms
I have 6 p3 motors so im now going to build 6 tens consisting of the p3 motors, 12 spoke baskets, each sub will have 2 medium spiders, 2.5" coil(same coil from type r's and kicker l7's, direct 8 gauge leads, deciding on cone..i have some cones but might use some sundown sa cones.
Here is a pic before the spiders come in...Ill get better than cell picks later
Old 05-07-2012, 10:56 PM
Dunbar91's Avatar
0/11 sssss6816
the basket actually is a cool black metallic flake
Old 05-08-2012, 07:15 AM
0/11 sssss3842
Def should make some nice 10s
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 05-08-2012, 02:13 PM
Dunbar91's Avatar
0/11 sssss6816
They they sound pretty damn good for being smaller motors..Heres the 12"
p3 motor, l7/type r coil,dual leads,dc cone/dual spider pack
Old 05-08-2012, 02:39 PM
Matt3824's Avatar
0/11 sssss3754
Where are you getting your coils, spiders, cones?
Old 05-08-2012, 02:57 PM
0/11 ssssss464
its funny how so many companies have interchangable parts that can be used together
Old 05-08-2012, 04:28 PM
Dunbar91's Avatar
0/11 sssss6816
Everywhere lol. I bout a bunch of stuff in bulk awhile back so have some left over. Otherwise i go through other companies
Old 05-09-2012, 12:17 PM
reeftopia's Avatar
i always need more power!
0/11 ssssss517
That looks nice put up a vidoe for us when you can.
2 18" Fourth Order build this weekend-Tips before build sxpimpin Enclosure Discussion & Design Construction Help 10 03-15-2012 09:13 PM
temporary budget build...94 xcab ranger (work truck build) CodyBrown2013 General Car Audio Discussion & Questions 8 02-17-2012 10:44 PM
S-10 truck build and blow-through build DevinG17 Build Logs 82 02-16-2011 02:58 PM
SPL_II's Team CACO Build Log <--- First real Build! SPL_II Build Logs 123 09-23-2010 09:44 PM
deepsilencer's new box build video designed by james(A.I),build by 99s10walled deepsilencer Car Audio Videos 1 08-30-2010 02:43 AM
