dirtriders impala trunk build - Car Audio Classifieds!
Old 06-17-2012, 04:35 PM
0/11 ssssss518
Default dirtriders impala trunk build
Well I just got my new car its a 2004 chevy impala. The build is going to be a little slow but I almost have everything I need. As of now I plan on doing a 4:1 fourth with 3 10s
Right now the headunit is really holding me up, I cant find much information on what integration harnesses i need to install my headunit. If anyone knows what to do could you please post. I have already removed onstar and I could care less about the door chime.
Old 06-17-2012, 04:54 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
gotta ask why such a big ratio.
Old 06-17-2012, 04:57 PM
0/11 ssssss518
efficiency and i have like 12 cubes to play with
Old 06-17-2012, 04:59 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
efficient also means peaky ..... i wish i had 12 cubes. i barely have 7.
Old 06-19-2012, 12:31 PM
0/11 ssssss518
test fit for the box im going to build
Old 06-19-2012, 12:54 PM
0/11 ssssss776
You can use a regular $20 harness man. No need for the one with all the bells and chimes if you don't want on-star. Go to your local audio shop, best buy, etc and they will have it.
Old 06-20-2012, 12:09 PM
0/11 ssssss518
thanks for the input, i actually ordered a relocation kit for 35$, i figured that way nothing could ever go wrong and i knew i would get the right plug for the hu
I'm going to cut the holes for the baffle later today when i get my hands on a circle jig and a router
Old 06-20-2012, 12:34 PM
Infinitelybaffled's Avatar
0/11 ssssss816
It's really not that bad. There are a lot of very musical setups that are a 4:1 ratio.
Inappropriate sig image.
Old 06-20-2012, 12:38 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
maybe ill do a 6:1 with the 4 xfl's... na jk. looks like a nice build man
Old 06-26-2012, 12:23 AM
0/11 ssssss518
Tags
fourth order, sundown audio, trunk, trunk build
jhg33k's trunk build jhg33k Build Logs 33 05-03-2012 12:54 AM
SPL Trunk Build db xTc General Car Audio Discussion & Questions 37 08-04-2011 12:03 AM
Trunk model 2 15s" impala. 3rdshiftdiscretion Enclosure Discussion & Design Construction Help 54 07-25-2011 06:56 AM
Trunk build questions? CivicWithTehBeat General Car Audio Discussion & Questions 1 04-18-2011 08:00 PM
2 dd 95z in the trunk of a 2003 impala More spl Enclosure Discussion & Design Construction Help 9 04-16-2011 08:25 AM
