Box Build for 4 Skar VVX 15's Monster Kerf Port - Car Audio Classifieds!
Old 06-18-2012, 05:22 PM
0/11 sssss1046
Default Box Build for 4 Skar VVX 15's Monster Kerf Port
Build this box in a couple hours this morning for a local customer from Tulsa, OK. Box is 12.5 cubes with a big kerfed port that's 162 sq. in. tuned to 32 hz for 4 Skar Audio VVX 15's running off an AQ3500 at 0.5 ohms. All of this will be going in a 4 door Chevy Blazer. Guy won't have the last 2 subs for another week or so, so it will be a while before we get numbers/videos. Box is fully resined on the inside with 2x4 bracing. Round overs on all corners, with flush mounts for the subs. Anyway, here's the pics.
Questions? Comments?
Old 06-18-2012, 05:28 PM
99Bonney's Avatar
0/11 sssss6246
Looks good man. Built in a couple hour? Lol must work quick!
2006 Tahoe
Subs- 4 Crossfire xs v2 15s
Amps-Crossfire 8k
Batts- 6 xs 3100s, 2400
Alts- 3 Mechman SMD 340s
Old 06-18-2012, 05:29 PM
0/11 sssss1046
I think it ended up being almost 3 hours, from first cut to applying the resin. Thank you though. Should sound pretty good.
Old 06-18-2012, 05:31 PM
0/11 sssss1564
Looks nice!
u scratchn ur ass or your head, but it could be both cause your heads in you ass.
Calebjcline's Avatar
Active Member
0/11 ssssss814
Miles is a hell of a box builder. Does great work and when he is building he stays hooked up on the task at hand. He has built several boxes for me and has always done excellent work. Never ceases to amaze me. Keep it up miles
Sent from my SAMSUNG-SGH-I777
Wes669's Avatar
Street light banger
0/11 sssss1869
How wide is that thing
'02 trailblazer
4 c2 threatcon 2 12s
Audioque 2200
Zapco 150.2
4 kinetic 1800s
Old 06-18-2012, 05:34 PM
0/11 sssss1286
no bracing?
Old 06-18-2012, 05:35 PM
0/11 sssss1046
38" wide
And thanks Caleb. Can't wait for you to hear Stephens box, and this one. Haha.
I tend to work fast because once i start building i get into a routine that i've always done and can knock a box out in no time.
Old 06-18-2012, 05:36 PM
0/11 sssss1046
Originally Posted by dcarcstms View Post
no bracing?
6th Picture. That, with fiberglass resin will be more than enough.
Old 06-18-2012, 05:38 PM
Esoteric's Avatar
0/11 ssssss259
What are the dimensions on it?
Sent from your moms bed!!!
2 HDC3 15's with DUAL Vertical kerf port Miles Build Logs 6 02-25-2012 07:37 PM
Box Build: Single SKAR VVX-12 DonH Build Logs 0 05-04-2011 11:48 PM
