4th order wall (3) xcon 15 alero aq3500d.1 - Car Audio Classifieds!
Old 06-27-2012, 11:53 PM
0/11 sssssss50
Default 4th order wall (3) xcon 15 alero aq3500d.1
update
ordered 2 dc level 3 18 d1's today
http://i.imgur.com/NfJqQ.jpg
Old 06-28-2012, 12:07 AM
0/11 sssssss50
It could be 3 ported/1 sealed. The difference between ported isn't much at all (1dB) but the 4th order has a +6db peak at 36-37Hz when tuned to 40 Hz, it is the same as ported before 32 hz and after 45 hz (45 hz @ 0dB), 60 Hz @ -5dB. Would 1 cube sealed be choking it? Is 3 too small? 42.5 hz port tune = 0dB @ 50 hz w/3 & 1 cubes (more preferable if 2.5 & 1.5 is too low).
2.5 & 1.5 have a +4db peak over ported between 35-55 Hz.
I was told that bandpasses are distortion monsters. thats not true if you set it up properly, right? if you set the gains and the filters correctly how could you go wrong? do they not provide good lows down to 20hz or something and move a lot of air up top?
Old 06-28-2012, 12:17 AM
0/11 sssssss50
Will I even gain with a 4th order or should I just stick with 12 cubes @ 32.65 Hz (12" of port per cube/adjustable tuning)?
Old 06-28-2012, 02:11 PM
crandis16's Avatar
0/11 sssssss76
I'm tuned in, my room mate last year had an alero with a DC lvl 4XL trunk build
Old 06-28-2012, 06:48 PM
0/11 sssssss50
Looking for 3 15's wired to .8 or 2 18's wired to .5 for $600 local pick up. 2 dc level 3 18's are 800 shipped for me but i doubt theyll take the power!
Old 06-28-2012, 07:04 PM
crandis16's Avatar
0/11 sssssss76
how are you going to wire to .8ohms with 3 subs? 800 shipped for 2 lvl 3's sounds a little high.... I was able to get 1 lvl 4 12 for less than $400 shipped
http://www.stevemeadedesigns.com/boa...l-3-m2-12s-d4/
Old 06-28-2012, 09:26 PM
0/11 sssssss50
im pretty sure 3 wires into either .8 or 1.2, s4's though. probably going to go with 2 18 d2's anyways so i can do .5 ohm.
Old 06-28-2012, 10:05 PM
crandis16's Avatar
0/11 sssssss76
.5ohms daily? or just for competition? From what I have heard from a lot of people, you shouldn't run your subs at .5ohms daily unless you have REALLY good electrical in your car. I would suggest getting 2 dual 4's and running them at 1ohm but that's just my personal preference
Old 06-29-2012, 12:32 PM
0/11 sssssss50
I'm doing .5 with a Singer 270 amp alt and 1 or 2 xs batts, it should be OK. The amp would actually only ever see .5 when the subs aren't moving, any other time because of box rise the amp will see about 1-2 ohms after rise anyways so it'll be okay. If I did 1 ohm than I'd still have rise up to like 3 ohms so .5 is fine for daily.
still need 2 18 d2's for $600.
Old 07-05-2012, 05:13 AM
0/11 sssssss50
I bought 2 DC Level 3 18 d1's for $640 shipped .
ported wall or 4th order wall jmkanek Enclosure Discussion & Design Construction Help 12 05-12-2012 09:37 PM
4th order wall? tommytee General Car Audio Discussion & Questions 16 01-27-2012 04:01 PM
4th order blow through or wall? Re_Silverado Enclosure Discussion & Design Construction Help 14 12-05-2011 07:25 PM
4th order wall? Russellabt General Car Audio Discussion & Questions 0 05-21-2011 07:50 PM
Plans for a 4th Order wall grimreper912003 General Car Audio Discussion & Questions 12 01-10-2011 02:19 AM
