Honda Accord 4 door Trunk Build - Car Audio Classifieds!
Old 07-23-2012, 05:24 PM
0/11 ssssss386
Default Honda Accord 4 door Trunk Build
Built this trunk for MWSPL extreme trunk ( mic 12" outside driver window 30 sec on music avg) and KAOs1 ( 3 minutes of music full tilt mic on the dash)
2- dd Z9515's and 1-DD M4a 2 Oddyssey Pc 1800FT batts
I really wanted 2-15's front firing, but I only had 33 inches of width. So this is what i came up with, basically I had to make a fiberglass tub in the spare tire well and use that glass tub as the port which exits under the box:
tore out the old box:
built a fiberglass shell in the spare tire well and built the box up from that:
top half of the box in before I covered it up. Each piece was built inside the trunk:
tried some angle iron for bracing
Every piece was a biotch to get in and each part was custom cut to fit, this is the first layer of the back wall going in:
second layer on the back, had to cut those squares so the batts would fit later:
Under the box on the back I had to close up the fiberglass shell and connect/glass it to the top of the box:
put a ledge in for the batts and amps:
inside box :
Ok so the box ports under the woofers via a fiberglass bottom that follow the contour of the spare tire well:
glassing the front of the box/port:
side panels to make it pretty:
lots of tape used to prep for glass:
basically this is what the front looks like now, I need to do some more bondo work to get it smooth:
I upgraded woofers:
back end carpeted:
orginaly I used 3 group 31 batts but I changed this:
Old amp over the batts DD Z1A
NEW batts...they use these in amored personel carriers so I am told..130lbs EACH!:
wiring them up:
new amp is M4a:
and it just all BARELY fits:
some numbers @ 3k I think this was:
2013 and 2011 Midwest SPL Extreme Trunk Champ
94 Honda Accord
Two DD 9915 SC front firing out of the trunk
2 DD M4a's
The Following User Says Thank You to Kreepn For This Useful Post:
Anton Miller (07-24-2012)
Old 07-24-2012, 08:04 AM
marquez7890's Avatar
0/11 ssssss628
nice build
95 Honda Accord, Nook Hd+ tablet
Team Ascendant Audio 18",
2006 Civic, Zv4 10"
Old 07-24-2012, 08:54 AM
0/11 ssssss386
Thanks man!
94 Honda Accord
2 DD M4a's
Old 07-24-2012, 11:00 AM
0/11 ssssss628
do you have a high output alt and do you/did you have any problems with the back part of your roof, cause mines rattles super loud like something broke and your system is like 3 times louder than mines?
2006 Civic, Zv4 10"
Old 07-24-2012, 01:52 PM
BKNIGHTS's Avatar
0/11 sssss2949
Feedback Score: 61 reviews
Nice build. But whats with the tiny pics? Link the full size pics.
Old 07-24-2012, 01:56 PM
0/11 ssssss386
220 amp alt and yes I did break the healiner roof clips so it used to rattle. It does flex there a lot even with dynamat.
I tried all the link settings and this was only one that would post thumbnails? Which one am I supposed to use?
94 Honda Accord
2 DD M4a's
Old 07-24-2012, 02:09 PM
0/11 ssssss111
Looking forward to seeing this!
Old 07-24-2012, 02:27 PM
BKNIGHTS's Avatar
0/11 sssss2949
Clink of the IMG Code and just past that here
Old 07-24-2012, 02:29 PM
BKNIGHTS's Avatar
0/11 sssss2949
And by the way. HOLY SH!T monster batts
Old 07-24-2012, 02:36 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
nice build man. that score sealed?
6 SA 12's in Honda Accord Trunk - NO WALL! Oldbass38 General Car Audio Discussion & Questions 6 05-21-2011 09:17 PM
91 Honda Accord Build partyboy6686 Build Logs 15 01-04-2011 07:00 PM
Want a wall build for my 99 honda accord! PLZ! cvxspl15 Off Topic Chat 8 12-23-2010 02:22 PM
2010 Honda Accord Coupe Build Log Mirage_Man Build Logs 5 07-28-2010 10:30 AM
2009 Honda Accord budget build gbo559 Build Logs 0 11-16-2009 04:31 PM
