Obsidian/Sundown Escalade build - Car Audio Classifieds!
Old 07-30-2012, 10:05 PM
Dbmonster's Avatar
0/11 sssss1217
Default Obsidian/Sundown Escalade build
I've been slowly working on this build since June when the obsidian 18's finally came in from the first pre-order. Everything is done other then wrapping the console and box in leather/vinyl. I've had it playing for a couple weeks now, but I haven't had time to do any tuning or testing. Once I do I'll post vids and numbers. I'm definitely very happy with these subs, they're holding up pretty well so far considering I'm putting almost 5x the rated power to each sub.
equipment list:
Pioneer avh-p4300dvd head unit
XS power d2400 under the hood
XS power d3100 in the back (will eventually be 2)
Sundown 4500d
2 Obsidian OA-18's
Box specs:
11.5 cubes net
4 6" aeroports, 17" long
tuned to 32hz
double baffle with internal bracing
Now on to the pics
This is what everything is going into
this is the false floor that will bolt down using the stock cargo tie down holes, and cover the entire cargo area. the box will be screwed down to this, and all wiring ran under it.
WARNING: Due to high sound pressure levels, all passengers are encouraged to remove any and all tight or restrictive clothing such as bras, thongs, etc. before entering this vehicle.
Old 07-30-2012, 10:15 PM
Dbmonster's Avatar
0/11 sssss1217
This is the beginning of the center console between the rear seats that will hold the rear batteries.
here it is with all the edges rounded over and the lid cut flush and rounded.
Filled all the screw holes with wood filler
The height of the console looks high in the pics, but in person when your sitting in the back seats it's perfect.
Old 07-30-2012, 10:25 PM
Dbmonster's Avatar
0/11 sssss1217
What could this be?
Mmmmm aero ports.
I've never used 6" aeroports before, they're huge in person.
On to the wiring, single run of 1/0ga power and ground from front battery to rear.
the main power/ground wires from the front battery come up through the bottom of the console, and the 2 runs of power and ground going to the amp come out of the back of the console.
Old 07-30-2012, 10:35 PM
Dbmonster's Avatar
0/11 sssss1217
Now to the good part, the box.
the ports are duct taped together for now until I decide if I like the tuning
Old 07-30-2012, 10:41 PM
Dbmonster's Avatar
0/11 sssss1217
And here is how it sits for now, eventually the console will be upholstered in leather with a perforated leather strip stitched down the middle of the lid to match my factory center console between the front seats. and the box will be wrapped either in leather or vinyl.
And that's it for now.
Old 07-30-2012, 10:48 PM
ninos's Avatar
0/11 sssss2421
nice clean install bro
Old 07-30-2012, 10:59 PM
Loud and Proud's Avatar
Loyal Member
0/11 sssss1570
Feedback Score: 29 reviews
Looks really clean
Old 07-30-2012, 11:23 PM
Dbmonster's Avatar
0/11 sssss1217
thanks guys!
here is a quick video I took the other day, I'm still going easy on these subs so this is nowhere near full tilt. once I have everything tuned in I'll make a better video.
Obsidian 18's in my Escalade - YouTube
Old 08-01-2012, 07:43 PM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
Looks good man
Old 08-09-2012, 08:25 PM
0/11 sssssss15
How many watts is that amp?
Obsidian/Sundown Ext Cab Ranger build tylork92 Build Logs 44 01-26-2013 11:49 AM
team sundown escalade wall build woofer cooker Build Logs 56 04-19-2012 10:00 PM
-2008 escalade build- Justin Team NWSPL 9 04-04-2011 04:26 PM
Box build for 2008 Escalade FLAstrongman Build Logs 45 11-07-2010 12:55 PM
2002 Escalade Build RidnClean Build Logs 76 05-10-2010 04:21 PM
