Hand-sculpted aero flares (build)... - Car Audio Classifieds!
Old 08-01-2012, 10:00 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
Default Hand-sculpted aero flares (build)...
These will be for a buddy of Violence's and, minus the router used to cut the circles, will be made using nearly 100% handtools + sandpaper Let's get started...
What I had to start with...
Getting there, still needs sanded complete though, obviously.
Inner flare done...
To see more of the process...the inner flare (complete) and the outter flare (in process)...
More tomorrow
(you may notice a little left to be sanded on the 'finished' one...you'd be correct...a little bit more to be done there)
Louder. Lower.
Team Tupperware
Old 08-01-2012, 10:05 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
looks good,
i know its probly not the best investment,
but a wood lathe with a 16" throat would cut some nice aero's also
thats alot of sanding and shaping going on there
Old 08-01-2012, 10:07 PM
0/11 sssss8346
Originally Posted by sthrnbumpn View Post
looks good,
No joke, someone with a half decent wood lathe could whip out some slick aeros of any size darn quickly. And ye, it's a bit tiring tbh..ha.
Louder. Lower.
Team Tupperware
Old 08-01-2012, 10:12 PM
Boomsday's Avatar
0/11 sssss1929
Feedback Score: 25 reviews
wow is all i can say, thats alot of work for some flares
Old 08-01-2012, 10:17 PM
0/11 sssss8346
Louder. Lower.
Team Tupperware
Old 08-01-2012, 10:21 PM
toolmaker's Avatar
Mstr of mtl
0/11 sssss2192
check craigslist. See them on there all the time for cheap( wood lathes)
E-mail -
Old 08-01-2012, 10:22 PM
0/11 sssss8346
Free is even better
My greatgrandfather passed away a while back and I will be inheriting quite a bit of stuff from his shop...he just may have (hint) a lathe and other goodies
Louder. Lower.
Team Tupperware
Old 08-01-2012, 10:25 PM
Dunbar91's Avatar
0/11 sssss6816
Feedback Score: 51 reviews
why not use a dremel for most of the inside sanding instead of the razr
Old 08-01-2012, 10:27 PM
0/11 sssss8346
Because (beleive it or not) the razor will remove mdf faster than a dremel can...a sharp razor shears it off quite efficiently tbh...you can take off close to 1/16" thick stretches with a steady hand (per pass). Just start the cut near the handle and then drag the razor back as you cut and it shears very nicely. But yes, for the sanding I couldve used a dremel but I wanted to make something purely with my hands for a change.
Louder. Lower.
Team Tupperware
Old 08-02-2012, 12:06 AM
newarkbeast973's Avatar
0/11 sssss7810
What is the pro in using/making them out of wood rather than using standard aeros sold on PE.com?
New build coming soon!!
(3) 4 inch aero flares Craig28 Wanting to Buy (WTB) 4 03-31-2012 11:28 PM
new 4" aero ports with flares lincoln ls Car Audio Trader (WTT) 10 09-18-2011 07:14 PM
WTB: 8 ' Aero Flares britdevine Wanting to Buy (WTB) 4 03-24-2011 09:43 AM
6" aero or flares taylorpro Wanting to Buy (WTB) 17 03-20-2011 03:23 PM
1- 8" aero port flares sx4life Wanting to Buy (WTB) 4 07-08-2010 07:58 PM
