2005 Ford Explorer 2 18" Obsidian Audio AQ2200 - Car Audio Classifieds!
Old 08-14-2012, 06:00 PM
0/11 sssssss74
Default 2005 Ford Explorer 2 18" Obsidian Audio AQ2200
Started basically a ground up build.
New head unit
New Subs
Plotting out bracing, port, etc
Gluing and building box
Bracing
My nephew in the box. lol. He actually went in through the port and back out it.
I talked my brother into TRYING to do the same thing.
Not loaded
Loaded
Still things left to do. Wire subs, finish amp rack, sound deadener on gate.
I will see how this box sounds and then decide on paint/covering, etc.
2005 Ford Explorer
1 x SQ-3500
4 x HDC3 12's
Box ported at 32hz
1 x Kinetik HC1800 underhood
2 x XsPower XP3000 Not near enough power wire.
Old 08-14-2012, 06:20 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
adding another baffle? And why so much port?
Old 08-14-2012, 06:34 PM
Wes669's Avatar
Street light banger
0/11 sssss1869
almost kept it below the seats.
'02 trailblazer
4 c2 threatcon 2 12s
Audioque 2200
Zapco 150.2
4 kinetic 1800s
Old 08-14-2012, 08:31 PM
0/11 sssssss74
Originally I wasn't going to add another baffle since I had to stay under the window line, but that has been blown out of the water now so I may. May invert the subs as well. I got the plans from someone else and that is the port I was told to build. It is tuned to 32hz.
I was trying to stay under window line but failed.
2005 Ford Explorer
1 x SQ-3500
4 x HDC3 12's
Box ported at 32hz
0/11 sssss1286
Deff not the best enclosure for that application
Old 08-14-2012, 08:40 PM
0/11 sssssss74
What's wrong with it?
2005 Ford Explorer
1 x SQ-3500
4 x HDC3 12's
Box ported at 32hz
Old 08-14-2012, 08:43 PM
0/11 sssss1286
Nothing ...just not the best design option
I have the same truck and have had 3 diff dual 18 setups
Old 08-14-2012, 09:09 PM
0/11 sssssss74
I would be open to suggestions. I know nothing of box design, thus why I reached out to someone else to help.
2005 Ford Explorer
1 x SQ-3500
4 x HDC3 12's
Box ported at 32hz
Old 08-14-2012, 09:33 PM
Wes669's Avatar
Street light banger
0/11 sssss1869
How wide is the box? I have an explorer with two 18s and it's below the window and it's 13 cubes with subs side by side.
'02 trailblazer
Audioque 2200
Zapco 150.2
4 kinetic 1800s
Old 08-14-2012, 11:09 PM
0/11 sssssss74
12ft^3 tuned to 33hz via a 16.5' tall x 8.5' wide port. 44.5" wide x 18" tall x 36" deep.
2005 Ford Explorer
1 x SQ-3500
4 x HDC3 12's
Box ported at 32hz
The Following User Says Thank You to dangar For This Useful Post:
1ndatrunk (06-03-2013)
Taylorpro's 1999 Ford Explorer Build -Sundownn, Singer, Audio Technix taylorpro Build Logs 522 04-05-2013 10:39 PM
Help Me Decide! Ford Escape or Ford Explorer? Raptor660 General Car Audio Discussion & Questions 31 07-21-2012 07:30 AM
1993 Ford Explorer "premium sound system" help DarkSideOfTheSpoon0531 General Automotive Chat 5 11-02-2010 05:09 PM
2005 ford escape Toone General Car Audio Discussion & Questions 1 09-13-2010 04:25 PM
2004 Ford Explorer build - pure pressure audio anj46907 Build Logs 19 09-26-2009 12:24 AM
