need help box recommendations for big bass - Car Audio Classifieds!
Old 08-15-2012, 08:55 PM
0/11 ssssss772
Default need help box recommendations for big bass
2002 impala ls need help tryin to decide on 3or4 sa8 or 2 sa12 i want some nice bass also i want some trunk space so any advice on wat amp and box and subs
Old 08-15-2012, 09:52 PM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
2 8's will take up a lot of space mainly because of the port length required for such a small volume. 2 12's will gain you better output, but with the silly shaped trunk opening on an Impala getting a box in there will be difficult. I'd suggest getting 2 SA10's, they be more than enough to get the car flexing and hitting you in the chest.
Edit: Grab a Crescendo BC2000 and a group 34 or 31 battery for the back.
Old 08-15-2012, 10:16 PM
0/11 ssssss772
so a box for 8s really takes up that much space i guess ive seen lot utube videos with small boxes so also i have a battery xspower d925 so how would i wire it up to amp n ground it
Old 08-15-2012, 10:20 PM
SacTownBully84's Avatar
0/11 sssss3682
Feedback Score: 51 reviews
hes trippin about the volume for sum sa 8s........half a cube each even with a monster long port ud see bout 2-3 cubes tops gross
98 Taurus
: CRESCENDO : AT : SKAR : MEMPHIS :
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 08-15-2012, 10:25 PM
0/11 sssss3682
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 08-15-2012, 10:26 PM
0/11 sssss3682
theres a general design....build that box and get a good 1500 rms amp it i bet it slams.....ive built a few boxes for sum sa8s ive had.....small boxes are the way to go with em
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 08-15-2012, 10:27 PM
0/11 sssss3682
notice the gross vol is 1.56 cubes.....pretty small if u ask me
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 08-15-2012, 10:30 PM
0/11 ssssss772
i dont kno how to build boxes so thanks for idea but i dont know how to use that cut sheet dimensions u sent pic of
Old 08-15-2012, 10:32 PM
0/11 sssss3682
well ur thread title says "need help box recommendations for big bass" ...so i gave box recomendations
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 08-15-2012, 10:33 PM
0/11 ssssss772
ok i figure thoses subs works better in small enclosures thas y i was like really is that much space required for 3 or 4 sa8
Box suggestions or recommendations theking Enclosure Discussion & Design Construction Help 9 08-17-2011 06:48 PM
Box suggestions or recommendations theking General Car Audio Discussion & Questions 5 08-16-2011 09:56 AM
Opti1533D Box recommendations? Raptor660 General Car Audio Discussion & Questions 1 04-12-2011 06:00 PM
18" Fi BL box recommendations dat517boi General Car Audio Discussion & Questions 5 11-03-2010 11:31 PM
Recommendations on box mjf595 Off Topic Chat 0 08-21-2009 03:53 PM
