Matt's 06 Tahoe Build - Car Audio Classifieds!
Old 08-26-2012, 07:47 PM
99Bonney's Avatar
0/11 sssss6246
Default Matt's 06 Tahoe Build
Vehicle:2006 Ex Police Chevy Tahoe
Subs: 4 Crossfire XS v2 15s
Amp: Crossfire 8k, BMF 600.2
HU: Pioneer 80prs
Batts: 6 XS Power 3100s, 2400
Alts: 2 Mechman 340a, 1 Stock
Wire: 8 runs Audiotechnix 0g
Deadener: 40sqft 80mil
In case you never saw, this is my last build log. Most of my gear will be transferring from my Escape.
99Bonney -> *** 2010 Escape Build *** PSi+DD
Bought this vehicle to be more competitive, looking to compete in DB Drag SS No Wall, and Bassrace in the 149.9 class.
Also it helps to pull my trailer around
Got her about a month ago sitting like this
First I removed the rear door trims so it would look cleaner.
Then replaced one of the speakers because it was blown with a Crossfire mp6 mid.
More to come once I get on my computer.
Old 08-26-2012, 07:54 PM
99Bonney's Avatar
0/11 sssss6246
Pioneer 80prs! So many functions I don't know where to start.
Getting wired up
What kind of space I have to work with, it's tight
How it looks installed. Wish it had a cubby hole instead of a half din slot. O well..
Great HU thus far
2006 Tahoe
Subs- 4 Crossfire xs v2 15s
Amps-Crossfire 8k
Batts- 6 xs 3100s, 2400
Alts- 3 Mechman SMD 340s
Old 08-26-2012, 08:09 PM
99Bonney's Avatar
0/11 sssss6246
Half the wire ran.
Then these showed up
2 340s and an external regulator! Alts up close.
Onto the box build I started yesterday. Specs: 12cft net w/12" of port per cube tuned at 35hz.
Measuring out the double layered square port
Don't even own a jigsaw but it was the easiest way to cut this square. Not my favorite thing to do but it works.
Mounted the first layer
Both layers on
Dry fit with one baffle on
Lastly, some pics of the gear.
Tomorrow i'll build the removable port, brace, and cutout sub holes.
Let me know what you guys think!
2006 Tahoe
Amps-Crossfire 8k
Old 08-26-2012, 09:35 PM
badmofo529's Avatar
0/11 sssss3329
so far so good! i dont think you will have any voltage problems lol.
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 08-26-2012, 09:42 PM
0/11 ssssss830
Looks great, tuned in!
Old 08-26-2012, 09:43 PM
99Bonney's Avatar
0/11 sssss6246
I hope not lol. Just trying to get some headroom for once!
2006 Tahoe
Amps-Crossfire 8k
Old 08-26-2012, 11:53 PM
massivespl's Avatar
0/11 sssss8409
ur doing it right this time 4real!
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 08-27-2012, 12:02 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
subd!
-Youtube Channel
Old 08-27-2012, 12:06 AM
Eric B's Avatar
LowBlowBro
0/11 sssss2140
If there was antenna's on the roof, make sure they plugged them up well!
Old 08-27-2012, 08:52 AM
99Bonney's Avatar
0/11 sssss6246
Yea I'll double check that, they plugged where the roof rack used to mount to as well.
So what do you guys think for paint? I'm thinking either a black stain or bedliner.
2006 Tahoe
Amps-Crossfire 8k
Enclosure Build: Matt's TB 10's Pioneer~Saturn Build Logs 28 08-21-2011 02:33 AM
01 tahoe build path2spl Member Rides & System Pictures 19 07-31-2011 06:33 PM
THiSiSTiNY's 05 Tahoe build thisistiny Build Logs 16 10-24-2010 10:26 AM
Enclosure Build: Matt's Dual 10's Pioneer~Saturn Build Logs 9 11-05-2009 07:25 PM
Tahoe Build RidnClean Build Logs 19 08-06-2009 12:24 PM
