93 Chevy Lumina 4th order wall build - Car Audio Classifieds!
Old 09-06-2012, 07:51 PM
xnewbx's Avatar
0/11 ssssss985
Default 93 Chevy Lumina 4th order wall build
***WARNING: There are 2 by 4s used in this build, do not bitch, do not complain. Turn back now if it hurts your eyes.
Ok, so that's out of the way, I will be running 2 Memphis Mojo 15s in a 4th order running off a Crescendo 3500. 2 or .5 ohm daily, 1/4 for competitions, if I ever find one around me. ~2 cbs. each sealed, and ~ 10 cbs. ported. ( will find exact port once I put everything else in )
Next, most people ask, WTF is a 1993 LuMina?
*About to paint it*
*done*
Starting the wall with the bottom ofc
2 by 4s are only for the bottom and back shell of the box, will be layered with 3/4" MDF
I hate angle cuts..
*2 by 4s end here*
Subloofers
Only sliding pieces into place to make sure they fit nice and snug
Time for moar layers
Separating the sealed boxes
Removable board the subs are mounted on
Cut off short because class. Will hopefully be finished by tomorrow night and vids to follow.
Old 09-07-2012, 12:16 PM
2 ft^3 sealed per diver? That's gonna get loooooooow.
Old 09-07-2012, 12:26 PM
upzaw2000's Avatar
Thredz lik Ur Mom- VIRAL!
0/11 ssss14427
wtf is wrong w 2x4's.... this looks like an excellent example of using them in the right situation.
you probably wont like me
Old 09-07-2012, 12:27 PM
MR_MT's Avatar
Active Member
0/11 ssssss741
in for pics
Nothing special
Old 09-07-2012, 01:22 PM
0/11 ssssss177
you have the haters of 2x4's saying why didnt u use box tubing and a welder since everyone and their mother has that stuff laying around, looks good man keep it up, my mom had a lumina back in the day was a tank factory batt was a bish to get to though
Old 09-07-2012, 01:35 PM
Infinitelybaffled's Avatar
0/11 ssssss816
Because its extremely weak. With sufficient bracing, it should be fine.
Inappropriate sig image.
Old 09-07-2012, 02:51 PM
upzaw2000's Avatar
0/11 ssss14427
it all depends on the build... not the cut size of a piece of wood... god there is some ****in idiots on here lately.
Old 09-07-2012, 02:58 PM
0/11 ssssss816
.............. OK Yeah, SURE....Whatever you say. It's a fact the 2x4's are not very strong when you have them that way. I've built tons of builds like that and they all needed significant bracing. So yeahhh I'm SO dumb. This build will be fine, but he could always gain SPL from building stronger.
Old 09-07-2012, 03:00 PM
upzaw2000's Avatar
0/11 ssss14427
U just contradicted the shit our of yourself....
seriously... let it go... your wrong.
Old 09-07-2012, 04:05 PM
0/11 ssssss816
Contradict myself? What, because I said that building method was weak but he will be ok? Maybe it's because OP is running 2 15's on only 4k. Strength is not that important to him. I hope it can hold up at least that.
2005 Chevy Avalanche 4th Order build damwhite Build Logs 78 09-29-2012 05:02 PM
1995 Honda Civic coupe 4th order wall build Russla Build Logs 14 07-27-2012 06:18 PM
ported wall or 4th order wall jmkanek Enclosure Discussion & Design Construction Help 12 05-12-2012 09:37 PM
4th order blow-thru chevy [Completed] joe98chevy General Car Audio Discussion & Questions 83 11-27-2011 02:02 PM
The Jeep : 4th Order No-Wall Build sundownz (Sundown Audio) 30 02-14-2011 05:44 PM
