06 h3 hummer - Car Audio Classifieds!
Old 10-02-2012, 09:43 PM
jorgesau100's Avatar
160+ DD ftw
0/11 ssssss424
Default 06 h3 hummer
06 h3 hummer
Subs hdc4 12s
Ass shot
Amps AQ 3500d.1s, only have one hooked up in the truck
Box for the 4 12s
First set up more to come
Box is 8.8 after displacment tuned to 39hz
I need to get more batts to run the rest of my amps going to build a battery rack to mount under the truck.
Old 10-02-2012, 11:03 PM
160+ DD ftw
0/11 ssssss424
Thinking about doing 6 12s in a wall all behind c pillars
160+ DD ftw
0/11 ssssss424
YouTube - h3 hummer 4 12 hdc4
Old 10-03-2012, 12:36 AM
massivespl's Avatar
0/11 sssss8409
that should get rather loud with all that power.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 10-03-2012, 12:39 AM
160+ DD ftw
0/11 ssssss424
Its ok right now but I can't wait till I get the bats to run my other amps.
I did a 151.3 with 1 3500d.1 @51hz
Old 10-03-2012, 12:41 AM
massivespl's Avatar
0/11 sssss8409
NICE score! imo
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 10-03-2012, 01:10 AM
160+ DD ftw
0/11 ssssss424
Thanks
Old 10-03-2012, 05:19 AM
HACKMUNCH's Avatar
0/11 sssss3892
i have the same truck, i have ho alt for it for sale if ur interested. ohio gen 250a. i can get you loud in that truck easy. i do mid 155 w 2-18" behind back seats.
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 10-03-2012, 05:25 AM
160+ DD ftw
0/11 ssssss424
How much for the alt
So what are your thoughts of a wall for 6 12s behind the cpillars
Old 10-03-2012, 05:41 AM
HACKMUNCH's Avatar
0/11 sssss3892
250 for the alt, it has custom smaller pully to do more at Idle. The alt is basicly new. The best I clamped from stock alt is 80a cold with engine at 2krpms. The ohio gen did 242a. I say no to the cpiller wall because you can be just as loud without plus ur only lookn at about 16cft from c piller.
TEAM TSA 2013
FACTORY BACKED
Trippi's Hummer HHR_Ed Build Logs 170 03-20-2012 07:55 PM
H2 Hummer Wall shadstrong Build Logs 44 08-22-2011 09:28 PM
Trippi's Hummer walled01alero Car Audio Videos 8 07-02-2011 12:17 PM
Hummer Build LyferXB9s Uninterrupted Build Logs 4 10-29-2010 09:28 PM
pics of my Hummer H2 ty_houston Member Rides & System Pictures 21 09-03-2008 07:22 PM
