SA-8's, Orion, and A Surreal Design In A Blazer - Car Audio Classifieds!
Old 10-21-2012, 06:24 PM
Active Member
0/11 ssssss731
Default SA-8's, Orion, and A Surreal Design In A Cherokee
95 4 door Blazer
Substage
4- Sundown SA-8's V1.5
Powered by a Orion XTR PRO 2400
Front Stage
2- Sundown Neo pro 8's
2 Crescendo FT1's
Powered by a Orion XTR 800.4
the design
Wood Cut and assembly stated
OK now a couple mock up pics these are the amp placement options i have come up with so far. Batteries will be recessed under the amp on the floor just need to cut the cargo floor out and weld up my box for them. anyways which ever amp is vertical will not be mounted to the box it will be hinged so that if i need to haul anything i can remove the box and fold the amp down flat then cover them and haul whatever it is i need to. Now which one looks better. Im diggin the 2400 being vertical and the 800.4 on the floor, one reason being is there will be a few more wires for the 800.4.
Build in progress
more to come in, may happen slowly not a lot of free time right now
97 cherokee
Sub: 4 Sundown SA-8's Sub Amp:Orion XTR PRO 2400
Highs amp: Orion XTR 800.4 mid and Tweet: Tantric Sounds Component set
Old 10-21-2012, 06:33 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
interesting box, what type is that?
Old 10-21-2012, 06:36 PM
Active Member
0/11 ssssss731
Its a dual chamber bass reflex . It should be pretty solid between 30 and 70hz
97 cherokee
Old 10-21-2012, 06:39 PM
0/11 ssssss928
yeah, thats nice ass box.
Old 10-21-2012, 06:48 PM
LEN671's Avatar
BASSHEAD from Guam!!
0/11 sssss1148
What would the actual tuning be on the box?
Solid looking box by the way.
DC LVL5 12's
3 - KINETIK HC2400
1 XSPOWER XS7500
1 - ALPINE 9886
2/0ga. WIRE THROUGHOUT
Team DC Audio 2012
Old 10-21-2012, 07:00 PM
Active Member
0/11 ssssss731
Well
Heres the info he gave me with the design
Dual Chamber Reflex for 4x SA8 subwoofers.
Info:
Suggested subsonic: 30hz on 2000w RMS
Placement: Subs will fire up towards roof with ports firing back along walls
Passband: 30-70hz
Birch is recommended for this build
97 cherokee
Old 10-21-2012, 07:01 PM
Active Member
0/11 ssssss731
And i still need to add the double baffle
97 cherokee
Old 10-21-2012, 07:29 PM
nice chevelle
Old 10-21-2012, 07:34 PM
Active Member
0/11 ssssss731
Its actually a 68 pontiac built out of canada. Its my younger brothers car storing it while my chevy 2 is at our shop
97 cherokee
Old 10-21-2012, 07:37 PM
0/11 ssssss473
Im doing the same subs in a 4th order on a dat hellfire 2500 prototype amp it should sound good
The Following User Says Thank You to Stonepatterson For This Useful Post:
bsills09 (12-07-2012)
got my design, thanks surreal 98Expo General Car Audio Discussion & Questions 7 11-05-2012 11:10 PM
Box design for 2 SA-8's Ryan1126 (Sundown Audio) 18 03-01-2012 04:24 PM
4th Order design from Surreal 3rdshiftdiscretion General Car Audio Discussion & Questions 15 09-23-2011 06:13 PM
box design for 2 sa-8's what do you think? Dbmonster (Sundown Audio) 2 05-14-2011 06:57 PM
Which design for blazer? Xtremelegend General Car Audio Discussion & Questions 22 03-21-2011 08:08 AM
