Walled F250 3 -18in SP4's - Car Audio Classifieds!
Old 10-23-2012, 02:05 PM
SWIFT's Avatar
0/11 ssssss656
Default Walled F250 3 -18in SP4's
Well Figured I would add my Build log here. I have changed it several times over the last year and am now happy with the outcome, well for now. LOL
My truck is a 2007 F250 Harley Davidson Edition
ARP head studs, EGR delete, Oil cooler, Full 4in Exhaust, Innovative custom tuning, Suncoast Billet race trans and converter.
The goal here is to be very loud, low and sound good doing it. I'm hoping for 154's but want to do it peaking low, I would like 152's+ around 30hz, but main goal is to sound good, this will not be a burp box but built for demos.
Updated Equipment List for this build
Power / Electrical
Mechman 370amp alternator, over 200amps at idle.... props to Mechman
Adjustable voltage regulator set at 14.7v
4 XS D3400's, 4 runs of power, 2 runs of ground to back batteries (will add 4 more XP3000's when other amp is in)
wiring is Knu ofc 1/0 and also a 100+ft Coleman 2/0 ofc stage cable
Head Unit
Pioneer deh80-prs (running active)
Mids and Highs
Alpine PDX 4.150 on mids, Digital Designs SS2 on highs
2 Rockford Fosgate Punch Pro 6.5's
2 Rockford Fosgate Punch Pro 8's
2 Crescendo FT1 super tweeters, may add 2 more
Subs, box and sub amps
1 Crescendo BC 5500 at .5ohm (will add the 2nd amp after Holidays and run them strapped at 1ohm .5 each)
3 FI SP4 18's, dual 1, cooling, spaced spiders, loaded
The wall will be completely double walled 3/4in 13 ply Russian Baltic Birch with 1/2in all thread bracing
20cuft, 277in of port tuned at 31hz.
let the pics begin. I do all my builds by myself. I have no one to blame if it sounds like ass, lol.
The used a total of 7 sheets of Birch with very little scrap at all.
here is my last setup that was 14cu tuned at 30hz and it did a 149.8 at 30hz and 150.6 at 35hz and sounded great.
False floor that will hold the box and batteries and wiring will be underneath it.
This shows battery and amp placement, this is the old box but nothing is changing besides the actual box / wall
Doors hold one Rockford 6.5 pro Audio Mid and one crescendo FT1 tweeter
head unit, radar detector, volt meter etc
amp placement
start cutting and doubling up. Entire box is double walled
2012 F250 Lariat, lifted on 22's and 35's
4 DSS Ethos 18's flat wall, 2 Ampere Audio 7500.1's
Mechman 370, 9 batteries, Rockford Punch Pro front
Team DSS / Team Ampere Audio
Old 10-23-2012, 02:06 PM
muriloalvares's Avatar
0/11 sssss1252
nice!
Old 10-23-2012, 02:10 PM
SWIFT's Avatar
0/11 ssssss656
Baffle
rounded inside edges
monster
assembly mock up
Looking up into port showing the 45's flowing into it
Looking down in box through port opening
Port assembly\
Paint and sanding port
How about some bracing
Starting to Glass and resin inside, smooting the flow into the port
Assembled and ready, all corners rounded and smoothed inside, rounded port inside and out, box is a beast.
well over 400lbs empty
Old 10-23-2012, 02:11 PM
SWIFT's Avatar
0/11 ssssss656
The suspects
empty truck
This should be interesting
Hell I can do this
wall install, 3 18's - YouTube
Perfect fit
1/4in on each side of box at door handle
wow
Subs installed
Time to seal it off and make beauty panels
sorry for the shitty photo
I made the panels extend to the B-pillar. Not sure if this helped but its nasty on the low notes and moves a ton of air for one amp.
I will still add sme leather accents to the face of the wall. But im in no rush now.
It sounds amazing and is loud as piss. Not sure what it will meter but the goal was 152's on music and doing it low. Remember this isnt built for numbers but to be loud to the ear. My last 150 setup sounded louder than some 154 setups I sat in...... honestly. I dont know it may meter way higher than I am thinking. Its hard to breathe sitting in it sometimes.
here are a couple vids before it was sealed off. Its louder and lower sealed off. I will get new videos and some hair tricks on vid soon.
3 18' new setup - YouTube
Old 10-23-2012, 02:17 PM
xnewbx's Avatar
0/11 ssssss985
Dang looks nice, but I was wondering if there is any significance in the small pieces of wood between the subs.
The piece that's in the bottom left
Old 10-23-2012, 02:18 PM
99Bonney's Avatar
0/11 sssss6246
Looks good man! I hope you at least reach your goal and then some
Old 10-23-2012, 02:20 PM
upzaw2000's Avatar
Thredz lik Ur Mom- VIRAL!
0/11 ssss14427
nice!
you probably wont like me
Old 10-23-2012, 02:26 PM
SWIFT's Avatar
0/11 ssssss656
YES!!
They add some serious bracing without having to eat the space of a long 45. I use liquid nails and then one screw to each side. I do this on alot of builds.
The round dowels wont hurt airflow and they can be added once complete and they help brace both pieces they connect to.
here is my last box. Mofo was seriously solid
Old 10-23-2012, 02:29 PM
SWIFT's Avatar
0/11 ssssss656
Sorry if you meant the rectangle pieces that are rounded actually between the subs then Im not sure honestly. There was a significant less "thud" sound when hitting on the baffle with my palm after adding them. I like to brace, hit and listen and brace more anywhere I hear a more hollow sound. lol, call it overkill I guess
The Following 3 Users Say Thank You to SWIFT For This Useful Post:
BKNIGHTS (10-23-2012), legend654 (11-17-2012), xnewbx (10-23-2012)
Old 10-23-2012, 02:36 PM
RE_XXX's Avatar
0/11 sssss3182
Very nice build!!!
Amps- Crossfire XS-8X
Wire- 6 runs Stinger
The Following User Says Thank You to RE_XXX For This Useful Post:
rab6969 (10-23-2012)
FI 18" SP4's D1's tricky0303 18" Subwoofers 6 08-29-2012 01:46 PM
3 - Fi SP4's Hot chick demos and Funny bass reactions :) Anton Miller Car Audio Videos 2 05-28-2012 01:22 AM
18in of sexiness nuboot General Car Audio Discussion & Questions 4 02-20-2012 04:55 PM
FS: 18in Fi btl n2 d2 sub serjr711 18" Subwoofers 19 11-12-2011 11:43 PM
18in v1 recone akmarcos12gauge (Sundown Audio) 0 05-10-2010 02:52 PM
