Blow thru for 4 15" psi platform 1's - Car Audio Classifieds!
Old 10-31-2012, 10:28 AM
reeftopia's Avatar
i always need more power!
0/11 ssssss517
Default Blow thru for 4 15" psi platform 1's
Well I got my design the other day I need to start building soon I should have this done pretty soon!
Box is a 4th order blow thru in my standard cab F150. Power will be a little low at first I'm thinking ether my IA [email protected] ohm or my Orion 2500D @.5 ohm. Electrical will be upgraded slightly.
Old 10-31-2012, 10:34 AM
reeftopia's Avatar
0/11 ssssss517
So far I have a HO alt 250amp
Shock power wire upgrading to 2 runs soon.
1 c&d 102ah batt soon to add 1 more.
Sorry some of the photos have my current set up in them. I couldn't find photos of equipment only.
Old 10-31-2012, 10:38 AM
reeftopia's Avatar
0/11 ssssss517
Box is a 1:1.5 ratio it should sound good daily. But I hope to hit over a 150( keeping my fingers crossed) and some hair tricks.
Let me know if you have any suggestions to help me out, thanks!
Old 10-31-2012, 10:43 AM
infaredsinsor's Avatar
0/11 ssssss769
I have that same Orion amp and got the same HO from Powermax. How do you like that alt and have you had any issues with it?
Subs, amps, and power
AFEX Fire Suppression Systems Quality Engineer
itrader info available on profile
Old 10-31-2012, 10:47 AM
reeftopia's Avatar
0/11 ssssss517
No I haven't had any problems with it. It's a little loud at high RPM but it puts out rated power! Lowest my voltage drops at idle is like 13.2-13.3 and while driving it drops to 14.1-13.8 I am hopin this will improve when I add a ground run from the front battery. (Also I'm running a stock battery up front) so after replacing that it should help out also.
Old 10-31-2012, 10:51 AM
0/11 ssssss769
I hear that. I thought my alt was crapping out on me and it turned out that my batts have turned defective. I have to replace them soon to avoid any damage to anything else. So it's no really "loud" music for me right now
Old 10-31-2012, 05:40 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
you should check out my old build log, had a 04(03 style) single cab f150 too, 4 sa15s 6th order blowthrough off a 3500, 2 3000s, and 1 AB1100.1
your build should be legit, should move some air!
92 Ranger Walkthrough
(Under Construction)
Old 10-31-2012, 06:14 PM
xnewbx's Avatar
0/11 ssssss985
I think these builds with the 'smaller' subs are pretty sweet since not all of us can afford such huge builds. Tuned in
Btw who designed your box?
Old 10-31-2012, 06:28 PM
Calebjcline's Avatar
Active Member
0/11 ssssss814
Looks good. Doing a 4th in my single cab as well. Should be a lot different than Subs behind the seat. Should have a pretty nice bandwidth with the smaller ratio.
I'm doing 4 sa 12s in a 4.1 ratio on a saz3500
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
Old 10-31-2012, 07:55 PM
reeftopia's Avatar
0/11 ssssss517
Robin butler over at Bass head entertainment did my design. These platform 1 15" are a really good price
PSI platform 2 12" 98Expo 12" Subwoofers 11 10-13-2012 11:06 AM
Psi platform 2 18" Undadog 18" Subwoofers 4 10-07-2012 06:45 PM
2 psi 15" Platform 2 build * hovee Build Logs 20 07-15-2011 01:14 PM
(SOLD) 12" PSI Platform 1 Pieper 12" Subwoofers 64 11-18-2010 04:57 PM
[SOLD] PSI Platform 2 12" HiloDB1 12" Subwoofers 19 07-23-2010 10:24 PM
