4th order blowthru sundown and crescendo - Car Audio Classifieds!
Old 11-05-2012, 07:53 PM
Calebjcline's Avatar
Active Member
0/11 ssssss814
Default 4th order blowthru sundown and crescendo
Well I finally decided I was gonna follow thru with my plans and cut my cab. Last setups I had I enjoyed and was quite impressed. I decided to get louder tho. Last setup consisted of 2 RF T0 10s on a powerbass 5k. Did a 147.9 @ 34 hrtz usaci style. Here are some pics uploadfromtaptalk1352166604450.jpguploadfromtaptalk1352166630549.jpg
The new setup will be slow as I have a lot of other things going on. Here is the list of equipment going in
4 crescendo pwx 8s (2 per door)
2 crescendo pwx 6.5s (kick panels)
4 sa 12s in a 4.1 4th order
1 saz3500 @ 1 ohm
2 aq super tweets
300 amp irraggi alt
As many batts as I can fit
4 runs of cadence and AT(2+ 2-)
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
Old 11-05-2012, 07:55 PM
Active Member
0/11 ssssss814
Big thanks to miles who has helped me out a ton.
Here is the victim
Old 11-05-2012, 07:57 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
awesome deal man. tuned in
-Youtube Channel
Old 11-05-2012, 07:58 PM
Active Member
0/11 ssssss814
Pwx 8s. Beasts
Old 11-05-2012, 08:03 PM
Active Member
0/11 ssssss814
Some pics of equipment
Old 11-05-2012, 08:05 PM
Active Member
0/11 ssssss814
Door panel progress
Old 11-05-2012, 08:27 PM
Re_Silverado's Avatar
0/11 ssssss590
Nice man. I loved my 4th order blow through. Most musical box I have ever built.
Old 11-05-2012, 08:29 PM
Active Member
0/11 ssssss814
Thanks. Should be what I want. Low end monster yet put up good numbers.
Old 11-05-2012, 08:31 PM
0/11 sssss1046
Stretching fleece on the other panel tomorrrow then start adding matte. Milkshake them, sand, and paint the panels. Then on to the box. Since finals are coming up progress on the panels will be slow, but slow for me seema to not take very long.
Old 11-05-2012, 08:33 PM
0/11 sssss1046
The 4th order will be 4 cubes sealed and 16 cubes port with 280-300 sq in of port tuned to 48 hz. Should get pretty nasty but still put up a great number.
2011 Harley Davidson F-150 on 30's . 4 DD 18's in a 4th order blowthru. banginHOE Build Logs 122 01-29-2013 08:19 PM
2 sundown e10's in a 4th order dcarcstms Car Audio Videos 1 03-19-2012 10:46 PM
BHE 4th order blowthru in a 93 accord 2 PSi Platform 1s iamamp3pimp Build Logs 35 11-05-2011 09:11 AM
4th Order Wall Video Log - Mercury Cougar - Obsidian/Crescendo nickfs442 Build Logs 4 09-30-2011 12:38 AM
Sundown E8's in 4th Order moneruff (Sundown Audio) 1 10-30-2010 03:11 AM
