lilsoccersully build log 2 18s in my bmw - Car Audio Classifieds!
Old 11-22-2012, 01:35 AM
0/11 ssssss855
Default lilsoccersully build log 2 18s in my bmw
hello all i guess ill start with a list of the stuff thats going in to the car and on with the pics!!
first build log so dont hassle me to bad
charging system consists of : 320 mechman alt , 2 runs of 2/0, one run of 1/0 scosche ofc, dual front and rear frame grounds, xs power d3100, spp2250
amp is an opti drive 7k
subs are fi reconed zcons
on to PIKKS
the alt
old subs
radio
got some new drills
the start of a stripper pole
the amp
the batteries need to clean up wires
Stinger spp2250 unboxing - YouTube
and on to the wall
Wall Build update part 1 - YouTube
tool maker made this up for me
Wall build update part 2 - YouTube
Old 11-22-2012, 02:03 AM
ispector's Avatar
0/11 ssssss376
R U running both the AA 500.1 and the opti 7K? Do u see a big difference between the two amps guts? Build looks good.
Old 11-22-2012, 02:11 AM
0/11 ssssss855
i guess i should have clarified its the opti 7k im going to see how it fairs if it blows im going to Americanize it hoping for 4k solid output but we will see and thanks !!
Old 11-22-2012, 02:14 AM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
I like that you made the roof of the box go all the way to the windshield. Will definitely help sealing it off from the back.
Old 11-22-2012, 02:18 AM
Ricksi30's Avatar
0/11 ssssss997
So they are stock ZCONs correct?
Head unit: Kenwood Excelon KDC-X996
Front stage: Alpine Type X mids Vifa Neo 1" silk tweeters
Component amp: PPI Bk800.4
Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
Sub amp: PPI Bk1300.1
Team SSA
Old 11-22-2012, 02:25 AM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
I like that wire alot. I have the same stuff. coppercableman FTW
Old 11-22-2012, 02:31 AM
0/11 ssssss855
that was the only idea i had to eliminate the sun roof. The 12s ripped the seal, kept leaking water. There is 4 layers of plywood above the box and the full piece of wood from the front to the back will be glassed into the pillars to seal completely
the 12s i had were stock they are using the same motors and building them into 18s not sure on the exact specs on the recones just know they should be done some time soon
here is a vid of the 12s when they were in the trunk 37 hz tune box
2 12 inch subs Hair trick - YouTube
i love the cable (wire ) does better then 1/0 under the hood
Old 11-22-2012, 02:37 AM
Ricksi30's Avatar
0/11 ssssss997
Awesome man I'm assuming if they are from Fi and you didn't request anything special they are zcon soft parts.
Team SSA
Old 11-22-2012, 02:53 AM
0/11 ssssss855
Yeah more then likely I have no complaints with my old zcon softies only had one tinsel lead burn on me because I was clipping it to living hell and back and playing 10 hz below tuning lol
Old 11-22-2012, 02:57 AM
Ricksi30's Avatar
0/11 ssssss997
Haha it takes a lot to destroy a zcon. I'm tuned in for sure! Do you have a build log on SSA?
Team SSA
Price quote for lilsoccersully lilsoccersully Alternator Price Quote Section 1 03-07-2012 03:56 PM
Masterbarber's 01 BMW 325ci build masterbarber Build Logs 19 01-04-2012 10:57 AM
BlackWaterOp BMW Build (BWOBMWB for short) BlackWaterOp Build Logs 18 04-26-2011 09:31 PM
Looking for build log: 12" dd rear deck BMW MurdaMax General Car Audio Discussion & Questions 3 09-16-2010 02:23 PM
BMW X5 Build... fiji24 Build Logs 3 06-29-2010 10:26 PM
