alt bracket mod - Car Audio Classifieds!
Old 12-03-2012, 05:31 PM
slowpoke's Avatar
newbie forever
0/11 sssss1160
Default alt bracket mod
94 suburban custom alt bracket. never bust over sized metal bracket. alot of people already know what happened with the suburban alt bracket. well here is my fix to the problem. i thought of just getting a new p/s alt bracket but then i would still have the risk of it busting off again so this is my lil project to eliminate any future problems. i extended the bracket downward to mount a 2nd alt but once i started cleaning it up for paint i found a crack in the case. so for now the singer alt will be running solo until i get another case or make it into someplace that has a tig. more to come tomorrow. the bracket has to sit for about 6 hours then it will get a 4hour long oven bake treatment and then sit for another 8 hours before being installed.
150db loud redneck
Old 12-03-2012, 05:33 PM
0/11 ssssss825
dang that was fast. Looking forward to seeing it installed.
do you still want some of those copper bars? I just sold 3 of them
Please upgrade your account if you wish to advertise in your sig.
Old 12-03-2012, 06:08 PM
slowpoke's Avatar
newbie forever
0/11 sssss1160
i would have had this done is less than a day easy if i had full use of both of my arms. my right arm is only up to about 60% functional so it took alot longer than i wanted it to.
150db loud redneck
Old 12-03-2012, 06:10 PM
slowpoke's Avatar
newbie forever
0/11 sssss1160
pm sent
150db loud redneck
Old 12-03-2012, 07:54 PM
0/11 ssssss825
What happened to your arm?
Old 12-03-2012, 09:48 PM
slowpoke's Avatar
newbie forever
0/11 sssss1160
had to have surgery done and the inflammation is putting pressure on the nerve cluster causing all sorts of wtf. its been really fun so far. about have of my entire arm has no feeling at all.
150db loud redneck
Old 12-04-2012, 04:12 PM
0/11 ssssss825
Wow. that is impressive that you are pushing through and still doing such great work!
Old 12-04-2012, 08:02 PM
slowpoke's Avatar
newbie forever
0/11 sssss1160
its not to bad doing something like this. just takes more time. the hardest part was using my 6lbs hammer for fine adjustments for the angles. most of the metal cuts are done with clamps and big cut off tools. the welding is the easiest part. now like what i have been doing today instead of finishing this project is changing out a radiator in a 06 impala. im currently on a pain relieve break. the owner is going to be all sorta ticked. once i got it out i noticed water coming out of the hyd lines for the tranny. his internal cooler breached.
150db loud redneck
Old 12-04-2012, 08:20 PM
0/11 ssssss825
dang. Give that arm a break.
Internal cooler? (I don't know anything about american cars or automatics...just german and manual)
Old 12-05-2012, 09:55 AM
slowpoke's Avatar
newbie forever
0/11 sssss1160
wish i could give the arm a break. bills are racking up and i had about 3 weeks of no money coming in. the arm got all the rest that i can afford. as for german cars, im not so keen on the german thing. as for manual transmissions, i truly wish every car/truck would come with them and automatics would still be for those that are disabled like what they where when they first came about. a manual is far more dependable, better mpg, more power directed to the wheels, far less moving parts, 5x the life span, easier to customize, much high torque handling, and if your starter goes out all you have to do is park on a hill.
150db loud redneck
DC Power Vortec V8 Dual Alt Bracket w/160 amp alt SundownSilverado Wiring, Electrical & Other Installation Equipment 5 07-13-2012 03:03 AM
WTB: 03 Expedition 4.6 H.O alt/ dual alt bracket PDAOaudio Wanting to Buy (WTB) 0 06-11-2012 07:16 PM
Alt bracket: Where to get it? 1ndatrunk General Car Audio Discussion & Questions 8 08-04-2011 06:40 PM
dual alt bracket and ho alt for dodge magnum arntsmag General Car Audio Discussion & Questions 1 12-28-2009 01:17 PM
