AQ/Atomic chrysler 300 build. - Car Audio Classifieds!
Old 12-18-2012, 07:28 PM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
Default AQ/Atomic chrysler 300 build.
Well everyone Im about to start what I hope is that last install in this car for a long time.
(Electrical)- Mechman 320 amp alt, externally regulated at 14.5 volts, 2 x kinetik hc2000. 2 runs of 1/0 postive, and 1 run if 1/0 negative. Big 3 up front, all 0 gauge grounds under hood and in the trunk for the batts.
(Headunit)- JVC AV 50 Double din.
(Front Stage) - The doors have already been fiberglassed front and rear. Fronts hold 2 6.5"s and the rears hold 1 6.5". I will be switching out the planet audio pros that are currently installed in favor of the Crescendo PWX's. The front stage is powered by a PPI Phantom 900.4.
The sub stage - 2 AQ hdc3 copper coil 10s powered by an Atomic AT-3000.1D. Box is subs forward, port foward sealed off from the trunk, 2.75 cubes net @ 32 hrtz. Now on to pics. I will be building the enclosure after Christmas.
Old 12-18-2012, 07:33 PM
1loudmonte's Avatar
0/11 sssss2167
Alt and head unit.
Old 12-18-2012, 07:35 PM
1loudmonte's Avatar
0/11 sssss2167
Front doors and amp.
Old 12-18-2012, 07:36 PM
1loudmonte's Avatar
0/11 sssss2167
Subs. Sorry for the mulitple post, but it was the only way it would let me post all of the pics. Hope every one enjoys.
Old 12-18-2012, 07:49 PM
BKNIGHTS's Avatar
0/11 sssss2949
Feedback Score: 61 reviews
doors look good.
Old 12-18-2012, 07:56 PM
1loudmonte's Avatar
0/11 sssss2167
Thanks, i still have to take them and get them wrapped in suede.
Old 12-27-2012, 03:32 PM
1loudmonte's Avatar
0/11 sssss2167
Well I have some updates and some new pics. Got some of the metal cut out from behind the rear seat so that my enclosure can sit flush up to it and seal off good. Cleaned up the installation of the 4 channel temporarely untill I get my second kinetik hc 2000 installed. Included is a pic of the enclosure. 2.75 cube net @ 32 hrtz.
(2015 MECA Street 3 World Champion)
2004 Dodge Ram Single Cab 1500
3 Incriminator Audio Judge 15s
3.25:1 Ratio 4th Order Blowthrough
1 x AA 9.0 TFHE, 2 x AA 150.4
4 X Crossfire XS-M8's, 2 x PRV Tweets
Old 12-27-2012, 03:55 PM
0/11 sssssss34
Dam I'm going to have to watch this. Keep the work going.
Old 12-27-2012, 04:17 PM
Mr.G6's Avatar
0/11 sssss4614
mechman 320s are a beast
my g6 has a 320 also
2000 Gmc Sonoma ext cab
Old 12-27-2012, 09:54 PM
1loudmonte's Avatar
0/11 sssss2167
Yea i love my 320, puts out plenty of voltage. The enclosure will be done and installed Monday. Still plan on adding another 1/0 ground run front to back.
chrysler 300 1loudmonte General Car Audio Discussion & Questions 3 11-27-2012 07:39 PM
1loudmonte - 06 chrysler 300 1loudmonte Build Logs 10 08-13-2012 12:49 PM
Chrysler 300 DC audio 15" XL box build Burbarry Build Logs 7 08-03-2011 02:33 PM
Chrysler 300 juancolchado Off Topic Chat 4 04-29-2011 06:52 AM
Chrysler 300 Build Burbarry Build Logs 5 09-08-2009 04:32 PM
