Kove Armageddon Z15 dustcap repair & box build on the CHEAP! - Car Audio Classifieds!
Old 01-05-2013, 12:26 PM
Pioneer621's Avatar
0/11 ssssss494
Default Kove Armageddon Z15 dustcap repair & box build on the CHEAP!
Got this sub a while back. Just thought Id post up the project I was working on since I dont post much. Just an experimental basic box really, wanted to try a side firing port, sonotube, etc. Original plan was to make a 6 PVC aero, but did not want to spend that much. So I settled on an 8 quick-tube / sonotube. Ill post the sketchup I did, but it shows the aero.
After all displacement the box is just a hair under 4 cubes. I have a port tuned to 42hz & another / half external tuned to 35hz. Want to play around with tuning so probably have some higher tuned ones as well.
Im not the best wood worker / dont really have the tools for it & might do things not quite right, but just like experimenting with stuff, so its probably not an ideal box, but thats how you learn, trying stuff out. Still needs some sanding.
On a side note this was a super cheap build, got the sub for free from a forum member & seen the MDF sheet free on CL, went out & picked it up around midnight off the curb, lol. Picture it halfway hanging out of a 1991 Lincoln Town Car trunk with some bungee cords keeping it from moving much for a 15-20 minute drive! Virtually a full sheet of 3/4 as well as a sheet of 1/2 MDF, haha. I only used the 3/4 sheet.
Only stuff I bought was screws, dowel rod & the port tube. Ive never used dowel rod for bracing & just wanted to test it out as I seen it while I was there.
Here are the box build pics: (plus sub repair pics, I used E-6000 adhesive for the dustcap)
First dustcap I bought got damaged in shipping, shipping it in a bubble mailer is a bad idea in my opinion, but the seller was easy to deal with & he sent a new one in a box as I requested.
Again probably not an ideal box, just something I wanted to test out. I ran it on about 500w & it was not too impressive, lol, have to see how it does when I can get more power on it. I will likely mainly use this for testing amplifiers I repair at the bench for now & was one of the reasons for the build.
Old 01-05-2013, 12:38 PM
Mr.G6's Avatar
0/11 sssss4614
aero is way to big lol
but other than that cool
the kove Z series is 1 of my favorite woofers..only rated for 1000w YEARS AGO
if you dont wanna mess with "custom" recones a FI Q recone with flatwound coil drops right in
BUT with ANY OTHER recone you need to use another basket OR space the motr and basket apart a good 1/2"
becasue those baskets do NOT have the cooling vents on the bottom
2000 Gmc Sonoma ext cab
Kove armageddon t3 box recommendations. bombout800 General Car Audio Discussion & Questions 5 11-24-2012 04:16 PM
[OHIO] Free Kove armegeddon Z15 rawlins87 Car Audio Freebies 21 07-30-2012 08:07 PM
Kove Armageddon Z15" Dual 4 rawlins87 15" Subwoofers 16 07-25-2012 08:30 AM
Kove Audio armageddon AG 1400 AMP? Papered_Up General Car Audio Discussion & Questions 1 04-19-2012 01:20 AM
Kove Kove Armageddon Z series motor cheap Jason19 Speaker Accessories & Parts 21 02-04-2011 02:19 PM
