console thingy build. - Car Audio Classifieds!
Old 01-14-2013, 10:24 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
Default console thingy build.
well I needed somewhere to mount my voltmeter, lc-1 and a bunch of switches, so i started cutting stuff apart.
first i cut the back off of the current console and used a piece of the plastic to glue it back in to make a place to mount the voltmeter.
for the other piece i use a old piece of 1/8" plywood, should work for this and paint pretty well, the face is very smooth.
I drilled a bunch of holes through the old plastic to give the glue a better area to adhere to. I used goop to attach it, should hold up pretty well. just bored waiting for it to dry. gonna sand the goop down some, add a little bondo, and paint the piece, should finish tomorrow.
Old 01-16-2013, 12:00 AM
btsteinb's Avatar
0/11 sssss3573
almost done, stepped on a switch by accident, whoops.
1st switch is voltmeter
2nd switch is mids amp
3rd switch is sub amp
4th switch it tweets amps
5th switch is fans for the mids amp
6th switch is fans for the sub amp.
only .1 off, need to charge the batts after a long day of abuse.
2001 Mid bass Center Console Build! buttphacekilla Build Logs 19 09-16-2012 08:02 PM
center console build help anyone?? buttphacekilla General Car Audio Discussion & Questions 68 01-20-2012 10:15 PM
WTB: Xbox360 console or PS3 console! 03navi Wanting to Buy (WTB) 6 11-01-2010 12:50 PM
2006 CRV center console build! andrewtexas123 Build Logs 25 06-25-2010 09:22 PM
pyrmid crossover thingy fatpat1080 Head Units, Processors & EQs 19 04-28-2009 03:35 PM
