Vectra build - Car Audio Classifieds!
Old 01-15-2013, 01:35 PM
0/11 sssssss85
Default Vectra build
Hi
Thought I might put some equipment into the Vectra winter beater I have hanging around..
I started off by adding a 0 gauge power supply to the boot and decided to use a battery as the distribution block (it is screwed into the metal floor with fastenings under the car)
TB3 under the hood
Alpine head unit and signal processor in a double din unit
Old skool rockford punch 40x2 on the stock speakers, I did have another amp lined up for the job but this fitted in the hole quite well and although it does not look it this is one of the best class AB amps money can buy!
I added a CXQ3 so I could adjust the sub amp from the front of the car without going into the head unit settings, it has a remote control for the front of the car which comes in quite handy IME
Things getting slightly more serious now with the soundstream XXX-10000D to power the subwoofer, this thing is rated at 10KW RMS if you can provide the power consumption....I will only be asking it to give out around 1500-2000w for the time being.
I would have liked to hide it away somewhere but that does not seem possible with something of this size.
I am sure the driver will be upgraded in the future for something that can handle around 4-5K but for now a single 12W7 from the loft will have to do, here we see the box in an unfinished state with the plan to make a false floor over the top of the box.
It is a 2.2cuft enclosure ported for 33hz with around 40" sq port
Cut some 6mm MDF to fit the boot area
And finish with a bit of ebay carpet.
I'll put a speaker grill over the port to stop anything rolling in there and never coming back out lol
Old 01-15-2013, 01:45 PM
AudioPsiho's Avatar
psihič
0/11 ssssss560
nice ... but u can still damage the sub in that position
Old 01-15-2013, 02:02 PM
0/11 sssssss85
True but the only reason it is inverted is because the box is very shallow and will not house the sub if it was mounted conventionally, it's not inverted to protect the cone.
Old 03-02-2013, 12:46 PM
0/11 sssss8594
Feedback Score: 55 reviews
whats the actual box look like??...that whole top part looks like a beauty panel otherwise i cant see how 2.2cu is THAT big...lol
Enclosures
Old 03-02-2013, 02:39 PM
0/11 ssssss102
T.F.S where you located i wanna hear this when i get back lol
Old 03-02-2013, 03:24 PM
0/11 sssssss85
Its 3.3cuft internal without the port
I put a large port in there just too see what it would sound like, 40sq if I remember right, ported for 34hz
It's only 5" deep so looks bigger than it is.
Dartford near London buddy, I have a couple of other cars with different systems in too, welcome to have a listen when you are over next.
Mercedes IB3 build on page 2
Meh
Also have an MR2 with some sealed JL goodness but have yet to do a build thread on that one.
Old 03-02-2013, 06:25 PM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
Meh
Do u have a vid of this setup?
Sent from my DROID RAZR using Xparent BlueTapatalk 2
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 03-02-2013, 06:27 PM
0/11 sssssss85
I think my mate might have taken a vid whilst I was giving him a demo, I'll ask him!
Old 03-02-2013, 10:47 PM
0/11 ssssss102
Sounds good I see where yah at.
Old 03-02-2013, 10:49 PM
Raptor660's Avatar
0/11 sssss5243
Ur Mate is a Dude! O wait... ur from the UK... Hahahah... Mate.. classic
2005 Buick LaCrosse
CLNFREAK'S build... rebuild.... build... CLNFREAK Build Logs 43 06-26-2012 06:25 PM
2 18" Fourth Order build this weekend-Tips before build sxpimpin Enclosure Discussion & Design Construction Help 10 03-15-2012 08:13 PM
temporary budget build...94 xcab ranger (work truck build) CodyBrown2013 General Car Audio Discussion & Questions 8 02-17-2012 09:44 PM
SPL_II's Team CACO Build Log <--- First real Build! SPL_II Build Logs 123 09-23-2010 08:44 PM
deepsilencer's new box build video designed by james(A.I),build by 99s10walled deepsilencer Car Audio Videos 1 08-30-2010 01:43 AM
