SLOW blowthrough build 4 18"Fi Bls - Car Audio Classifieds!
Old 07-29-2009, 03:44 PM
0/11 sssssss62
Default SLOW blowthrough build 4 18"Fi Bls
What do yall think about this?? will be going in my single cab 95 dodge ram
got the design from iamamp3pimp great guy
here are the particulars....
bottom 77 x 49
bottom 77 x 49
top 77 x 49
top 77 x 49
baffle 74 x 46
baffle 74 x 46
front 46 x 5
front 46 x 5
side 77 x 16
side 77 x 16
side 77 x 16
side 77 x 16
Port internal sides (4) 3 x 9.5
port external top 44.5 x 3
port external bottom 44.5 x 6
port external sides (2) 3 x 9.5
we are looking at 10 sealed and 17.75 ported
get dowels for bracing...
46x10 for the cutout to cab
10-11 feet of wood dowels for bracing...
i mean the dowels are 12 inches apart
fiberglass resin first then cover in bedliner... also resin the corners and dowels on the inside
so it'd be easiest to build the port outside the car
then slide it in
then screw it in from the sides
3/4 MDF sheets
its 5T x 19W >>>> PLEXIGLASS WINDOW
now make sure the inner lip is .5 bigger so you can flush mount the plexi on the inside.
like in the pics.
1995 Dodge Ram 1500 Reg. 5.2l V8
Will have a blowthrough setup pretty soon.
Memphis 16-MCD4KW (aKa THA BEAST) SOLD
REFS:jagblazer01
Old 07-29-2009, 03:47 PM
nismos14's Avatar
Super Moderators
0/11 ssss18246
Feedback Score: 64 reviews
What if I don't want to send to phone.
Looks like a nice install.
My Car, My Ears.
Old 07-29-2009, 03:53 PM
0/11 sssssss62
lol i guess that "send to phone is from photobucket" it wont let me erase sooo...
thanks man
REFS:jagblazer01
0/11 ssssss414
Should be great. Cant wait to see the build log. Great sketchup too
Old 07-30-2009, 12:16 AM
0/11 sssssss62
got these replies on some other forums...
not feeling it..
the sealed chamber will act much smaller than it is because its so short and long.... which will make the spaces farther away a lower pressure zone. With a box that short you don't want the woofers firing vertical.
do 6 15's firing horizontal
Ive got a pretty good idea about 4th orders, but Im no expert.
I just know that the design the OP has wouldnt work.
REFS:jagblazer01
Old 07-30-2009, 12:40 AM
0/11 ssss31247
It will work but not as a 4th order.
For it to be a 4th order, the port needs to be less than half the surface area of the panel which it is mounted in or the entire chamber acts as the port. (as in this case)
This is not bad but you need to count on it as a sealed enclosure not a 4th order.
Absolutely do not port the upper chamber since it will render your enclosure useless.
If the subs are firing downward it will "Load into the vehicle" well but I don't think it will set any SPL records.
I will look into a few things and see what I come up with since you seem to have provided all the dimensions.
Old 07-30-2009, 01:52 PM
0/11 sssssss62
ok thanks man
here are the max dimensions on my bed
7. Max dimensions:
here are the dimensions 49 1/2" wheel weld to wheel weld
77" front to back of bed
19" height
REFS:jagblazer01
Old 08-09-2009, 03:56 AM
thumper21's Avatar
Blow-thru KING
0/11 sssss1919
looks like mine for 4 18's.
Except its a 6th order
Speed and SQ
Old 08-09-2009, 07:42 AM
got160s?'s Avatar
0/11 ssss13630
Looks like a nice design.
I wanna see it when it's all done.
Any deadner going into this?
Old 08-09-2009, 07:43 PM
0/11 sssssss62
the cab and the floor of the bed will be dead...
REFS:jagblazer01
Slow Motion Water Balloons 92K1500 Uncensored Off Topic 4 06-24-2009 11:07 AM
KHARPS blowthrough KHARPS Build Logs 47 05-31-2009 12:17 AM
project low slow and loud.. s10 with 4 15's Member Rides & System Pictures 35 04-07-2009 01:28 PM
planning blowthrough, need some help mcdstvn General Car Audio Discussion & Questions 21 02-25-2009 09:00 PM
why is the forum so slow lately? caps Off Topic Chat 95 02-12-2009 11:23 AM
