00 quad cab dakota buld 8 12s - Car Audio Classifieds!
Old 02-17-2013, 03:16 PM
Nate Futuristic's Avatar
0/11 ssssss768
Feedback Score: 21 reviews
Default 00 quad cab dakota buld 8 12s
since i got a 4 day suspension from SMD im migrating more of my time/build/knowledge (what i do have lol) over to CACO... i normally just bought and sold over here but i think its time for a change... considering i can use taptalk with CACO and the moderators over on SMD are all on their periods the same time of the week...
so ill do a quick rundown of the build and then start the current pics i have.
Subs
4 IA lethal injection 15s
Sub amp(s)
sundown saz 3500d @ .35 daily
Mids and Highs (ordered and 1 day away!)
2 sets of soundstream 6.5s (model SC-6T)
(cheapos but i had to get away from AQ/SQ after the bullshit i dealt with from Greg)
Mids and highs amp
soundstream tx4.560
(again cheapo but should do until i can afford some decent comps)
H/O alt
STOCK ATM
(dropping into low 13s full tilt at 1500rpms)
Batteries
4 Deka group 34s in the back (possible 2 more depending on voltage)
1 group 34 upfront
wire
ALL SKY HIGH CAR AUDIO WIRE!!!
100 ft of 1/0
25 ft of 4 gauge
100 ft of 12 gauge
50 feet of 8 gauge
sound deadener
few sheets of stinger roadkill
40 sq ft of 60 mill AT
4 layers on the front roof alone
20+ cans of great stuff
NOW for Pics!!!
the truck
about 5 feet of 3/4 threaded rod (also have about 10 feet of 1/4 threaded rod im unsure if ill use)
AQ 3500.1 v2! (also the 25+ 2/0 lugs i got)
1 of the 5 batteries
tx4.560 got here yesterday
Old 02-17-2013, 03:24 PM
truebassjunkie777's Avatar
Team Bad Intentions
0/11 ssssss632
I'm tuned in for this build!
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
The Following User Says Thank You to truebassjunkie777 For This Useful Post:
Nate Futuristic (02-17-2013)
0/11 ssssss768
ive been moving to my new house ( ive been working out of a studio Upstairs apt for my last build) the last couple weeks and has taken alot of my time but i finally have a GARAGE!!
(dont mind the turd standing in their
(you can also see my custom made saw horses made by my boss and me 14g hotroll sheer and broke by myself and welded by my boss lol)
cutting some useless humps off the floor (structurally useless)
and more
some more
little more
now i can start the false floor (also got some deadener put on while it was around 10 degrees)
more updates tonight
Old 02-17-2013, 03:31 PM
0/11 ssssss503
Tuned in I have a 98 extended cab Dakota I've been building for a few years now
The Following User Says Thank You to kunzy420 For This Useful Post:
Old 02-21-2013, 03:50 AM
0/11 ssssss227
hes not a turd, he's ur ginger buddy :P
yeah, that bubble is noticable lol you get that fixed yet? and u still have my shears :P
Old 02-21-2013, 04:00 AM
Austin175's Avatar
0/11 sssss4224
Welcome this site is more user friendly as most on smd are butt hurt and uptight all the damn time.
Look forward to this.
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
The Following User Says Thank You to Austin175 For This Useful Post:
Nate Futuristic (02-24-2013)
Old 02-21-2013, 09:55 PM
0/11 ssssss263
is that the 90 dollar remy? if so how do you like it?
Old 02-21-2013, 10:44 PM
0/11 ssssss768
Yeah it is... I haven't gotten a chance to test it but seem like a cheap alternative that will do what
I need it to do
Old 04-08-2013, 09:26 PM
0/11 ssssss768
well its done lol
if you want to see the build up check out youtube
(i stopped taking pics as it was too much time to take them,upload, post)
http://youtu.be/XbSzahdZIWY
Old 11-23-2013, 01:29 PM
0/11 ssssss768
well time to update this. got a new job, out of legal trouble (probation)
was planning 6 15s in a flat wall but decided against
been pondering a new build for awhile
already made a deposit on the subs
they are not "4th order savy" according to t/s parameters but still gonna attempt it
worst case senario i pull the subs, seal up the baffle, remove loading wall and do a ported wall with 8 12s.
still gonna try my hand at the 4th order though
if it plays low and loud ill be happy not chasing numbers prolly wont get it metered since the only termlab around is all ****ed up
my attempt at sketchup
total room to work with
(internal dims of shell)
50 wide 37.5 high 34 deep
calculates to 8.3 sealed before 3/4 threaded rod ( will most likely add 5-6lbs of poly fill during DATS3 tunning depending on Fc)
ported is damn close to 18 think its roughly 17.96 after woofer,and bracing
(loading wall in pic is just for aesthetics im leaning more towards driverside port anyways)
subs will be 8 threatcon 2 12s
(dual 4s)
shooting for 6k but REALLY REALLY want a taramp hd 8000d
adding 2 more group 34s dekas to my 5 i currently have
280a excessive amperage alt
redoing all the wire with 2/0 welding cable
batts in the bed (building a box for em)
tonneau cover to hide the hideous rust
amps will most likely be on the driver side of the wall all depends on port placement
or in center console area
maybe a stripper pole if i get loud O_O
Why do alot of loud windowline suvs have small ports?? Magnet General Car Audio Discussion & Questions 27 10-18-2011 04:41 AM
brown 30 gb zune LoudCavi Miscellaneous Stuff For Sale 0 04-15-2011 09:08 PM
WTB: 2 MJ-18s, MJM 18s, or other budget 18s illbmeubu23 Wanting to Buy (WTB) 8 06-13-2010 09:20 PM
The brown truck visited! BASS_WARRIOR General Car Audio Discussion & Questions 13 06-19-2009 12:09 PM
Dakota Blowthru / 2 Fi Btl 18s & 12k+watts Derrick824 Build Logs 8 01-23-2009 04:00 PM
