Miles Single Cab SPL build - Car Audio Classifieds!
Old 02-22-2013, 04:28 PM
0/11 sssss1046
Default Miles Single Cab SPL build (not a blowthrough)
Well, I wanted to try and break a 150 this year in my single cab Dodge with all the equipment in the cab. Last season I only got to meter once with my daily box and managed a 147.5 dB outlaw. That was with a prototype IAD 15 on a BB2400.1 at 1 ohm. With voltage drop and the simple fact I don't believe those amps do anywhere near rated, I think it was sending about 1400-1500 watts to the 15.
This year I will be running a Massive Audio 3k (at 2 ohms) and a production IAD 15 (better coil and higher motor force than the prototype I ran last year. Anyway, first I'll list some pictures of last years setup, then I'll post of a picture of what I've done with my new box so far.
Old box:
New amp:
And a start to the SPL box. Going 3.2 cubes net with a 7.25" Dodecaport. What's a dodecaport you ask?
12 sides of goodness. More streamline than an Octaport and takes a lot less time than doing a full kerfed port.
Old 02-22-2013, 06:29 PM
AbsoluteAudio's Avatar
0/11 sssss1133
nice port
Old 02-22-2013, 06:35 PM
0/11 sssss1046
Thank you! I'll probably build the box tomorrow and throw a DD2515 in it. The sub is D2 so I'll have to wire it to 4 ohms. That's still around 1500 watts, but I'll still be able to tell if it's louder or not. The DD is in my last years box and sounds pretty good and gets pretty loud. About 1 dB down from the IAD on less power.
Old 02-22-2013, 07:20 PM
ridintwo6s's Avatar
0/11 sssss1791
i like the port. what are the angles to build that?
Old 02-22-2013, 07:22 PM
0/11 sssss1046
It's a 12 sided port, so each piece has a 15 degree cut on both sides.
Old 02-22-2013, 07:29 PM
0/11 ssssss247
loving the port
Old 02-22-2013, 07:31 PM
ridintwo6s's Avatar
0/11 sssss1791
sweet thanks bro
Big jcc's Avatar
0/11 sssss1178
Feedback Score: 47 reviews
Now your just showing off!! It Looks really good Miles
RD D5
RD 15" heavyweight
Old 02-22-2013, 07:39 PM
0/11 sssss1046
Lol. I'm tired of seeing all these Octaports, so i wanted to do something different. This is just 4 more pieces of wood, and a little shallower angle. Haha.
Since I have nothing better to do tomorrow I'll probably start working on the box around 9 in the morning. Get the new box built and the resin drying (once I apply it to the inside). Then take the old box out.
For everyones enjoymeant here's a couple of video. The first is last years setup, the second is last years box with a DD2515 and the Massive at 4 ohms.
Imperium Audio Reign 15" in Single Cab!!! - YouTube
DD2515 in a Single Cab - YouTube
Old 02-22-2013, 08:11 PM
ridintwo6s's Avatar
0/11 sssss1791
so the octo ports are on 22.5 degree angles?
Solo x 18 in a single cab C-LOS Enclosure Discussion & Design Construction Help 11 08-20-2012 01:14 PM
F/S: 92' Ford F-150 Ext Cab 5.8L 49K MILES!! *BEAUTIFUL* Winter_C Miscellaneous Stuff For Sale 12 03-26-2011 02:31 PM
90 chevy 2500 single cab build / rebuild brian84corvette Build Logs 10 10-22-2010 09:17 PM
2000 single cab dodge ram build 2 sa-12s 00ram360 Build Logs 16 10-13-2010 03:50 PM
2004 Single Cab Colorado Build RidnClean Build Logs 10 10-06-2009 06:17 PM
