Custom 2004 Honda Accord Double Din Install - Car Audio Classifieds!
Old 03-21-2013, 12:54 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
Default Custom 2004 Honda Accord Double Din Install
I had a friend come to me that wanted to put a double din in the lower pocket of his 2004 Honda Accord. Luckily for me they only make a single Din kit. A couple companies make double din kits, but they look mediocre at best. Custom Fab time commenced.
Had to Cut up the bracket, super glue and goop the trim ring to the face of the dash kit.
Then glued the mounting flap things of the radio to the back of the kit.
Continued with filling in the rest of the dash kit on the bottom where it curved down with the plastic I had cut out.
Filled it all with bondo and let the hand sanding begin. probably a good hour and a half of sanding.
Then I wanted to jump on the Plasti Dip bandwagon. Turned out perfect, the customer is very happy, seeing as the next shop wanted $300 to do it and needed 2 weeks to do it.
btsteinb's Avatar
0/11 sssss3573
more pics
Old 04-02-2013, 09:45 PM
btsteinb's Avatar
0/11 sssss3573
Installed.
Old 04-02-2013, 09:50 PM
0/11 ssssss159
nice work. looks like its supposed to be there
Old 04-02-2013, 09:52 PM
btsteinb's Avatar
0/11 sssss3573
Thanks, it was a lot of work to get it made and installed. The customer was great to work with through the whole process, which made it a lot easier.
Old 04-02-2013, 10:01 PM
logan23afroman's Avatar
0/11 sssss1813
what did you charge?
"Loudest Jeep Commander"
4xSundown sa-8''s
aq1200 with dual 0 gauge inputs!
141.6 on dash at 48hz with 594 clamped watts
Old 04-02-2013, 10:04 PM
btsteinb's Avatar
0/11 sssss3573
$120 for the custom bracket and to install a sub and amp.
Old 04-02-2013, 10:06 PM
btsteinb's Avatar
0/11 sssss3573
I prolly had about $40 in materials into the bracket.
Old 04-02-2013, 10:07 PM
0/11 sssss1813
thats a good price man, and very nice job to, what type of bondo do you use? 3m? evercoat?
4xSundown sa-8''s
Old 04-02-2013, 10:09 PM
btsteinb's Avatar
0/11 sssss3573
that stuff is a waste. I use some $13 a gallon lightweight filler.
Milkshake is your best friend.
How to install monitors to double-din? jessdabest77 General Car Audio Discussion & Questions 4 04-11-2012 01:22 AM
06 4runner double din install kit reeftopia General Car Audio Discussion & Questions 0 01-13-2012 10:34 AM
Double DIN Ford install kit sgtskip Wanting to Buy (WTB) 5 11-30-2011 08:13 PM
Double Din in a 2004 Wrangler? {anyone ever tried?} iamsonic General Car Audio Discussion & Questions 2 01-24-2010 10:19 AM
[SOLD]FS 200Amp Custom Alt for Honda Accord 370shipped waresgaragestereo Wiring, Electrical & Other Installation Equipment 28 02-08-2009 06:18 PM
