97 Seville build-Cpillar wall with Sundown, Crescendo, and Popcorn Sounds!! - Car Audio Classifieds!
Old 04-07-2013, 05:36 PM
Team Ampere Audio
0/11 ssssss779
Default 97 Seville build-Cpillar wall with Sundown, Crescendo, and Popcorn Sounds!!
Whats up guys,
So i tore out my 4th order last week, and wentr and picked up some birch Friday night. Ive been at it all weekend and have the shell pretty much done guys. Ive ended up with 10.9 cubic feet in the shell. I know, i know, that after bracing and displacements, imma be pushing it with space. BUT, im not using conventional bracing, (window bracing, big 45s taking up alot of space). Im using 1" steel piping top to bottom, and side to side. It wont take up anymore thamn 0.04 of space.
Subs are 3- 15" Sundown zv3 15s dual 2 ohm.
Amps are 2- 2500 watt Popcorn Sounds amplifiers
Wire is the 4 guage AT that Coleman just had the sell on!! Good Shitt coleman!! Real good shitt!!!
I also got a few rolls of Sky High 1/0 from those guys in Nevada. Gonna do 3 runs of each front to back. Already got dual inputs and all that stuff. Alt is Tenney 350a for now, untuil he finished my 400a.
Got a Deka Intimidator 55ah up front, gonna do some Powerware 100ah in the trunk. Anyway, on with the Pics!!!!! Gimme a sec to upload them
I may need some hel[ figuring how to port thees 3 subs
Old 04-07-2013, 05:55 PM
Team Ampere Audio
0/11 ssssss779
herzs some pics. As you can see, even tho it is a trunk car, it will have a "cpillar wall" when i get done. It wil lbe double badffled on the front. NOw, with thazt b eing said, the front baffle will also be the "beauty baffle" MEANING I WILL GLASS SOME ADDITIONAL MATERIAL, ON THE SIDES TO fill in any gaps that are visible./ It will be wrapped and painted. I will do some vinyl inlay on some spots and jusat straight paint on the other. shold be cool .
Old 04-07-2013, 06:02 PM
528hz's Avatar
0/11 sssss1792
LOL! Now that's how to take care of a trunk space problem.
Nice going dude! Looks like you got it pretty precise.
"When people think you have anger issues, your schedule clears up..."
Old 04-07-2013, 06:35 PM
qopiyu's Avatar
0/11 ssssss531
Agreed, plenty of space there!
Old 04-07-2013, 06:50 PM
Team Ampere Audio
0/11 ssssss779
Thank you man. What did hyou think of gthe drawingh i did by hand with my sharpie!! Its not sketchpu but itll do!!
anyway, i wont be able to do the 3 subs across, so does anyone hae any sugestions as to how to work the ports in tehre?? I cant think of anyway to do it other than having the subs offest and have a port to go with each sub. Kinda like in jmanetak acura integra build where he did 3 18s and had a square port to go with eavh sub. Im stuck on what else to do.
MAYBE PUT the subs in liknda of a "rainbow" formation?? Start about mid ways up the wall and stick one there, then at the very top in the center have another one, then on the right side, have one midways down .
Maybe do a triangle port?? Im lostand loking for ideas
Old 04-07-2013, 06:52 PM
Team Ampere Audio
0/11 ssssss779
also please note that none of this is screwed in but the bottom and the sides, That gap u see on the top wont be there, as this piece is just sitting up there for pictorial purposes and fitting
qopiyu's Avatar
0/11 ssssss531
what is the length and width on the front face?
Old 04-07-2013, 07:04 PM
Team Ampere Audio
0/11 ssssss779
O.D dimensions for fron face are
38" across (side to side)
29" top to bottom
Lemme know if this helps
Old 04-07-2013, 07:24 PM
Skip01's Avatar
Ladies MAN
0/11 sssss5551
Sheeshhh
Youtube VIDz :
Old 04-07-2013, 07:29 PM
Team Ampere Audio
0/11 ssssss779
Originally Posted by Skip01 View Post
Sheeshhh
What you think skip?? Ahats gonna be the best sub and port placement on this bitchh so i can hit a 150 and move some air?
Popcorn sounds deanmachine General Car Audio Discussion & Questions 5 03-11-2013 02:44 PM
Popcorn Sounds.. Did I get screwed? doug118 General Car Audio Discussion & Questions 39 02-10-2013 10:44 AM
talk about popcorn....sounds Jeffhulbert50 General Car Audio Discussion & Questions 39 01-14-2013 02:20 PM
