Single cab adventures! - Car Audio Classifieds!
Old 04-24-2013, 04:53 PM
0/11 sssss1046
Default Single cab adventures! (Fi, IA, DD, IAD)
Haven't done an extensive build log for my truck so I'll go ahead and make this one, which will be a step by step of everything I've ever done with the truck (as far as stereo's go). I'm currently 11 dB louder than I was with my first system, so this truck has come a long ways (and has had many broken panels), AND I've kept it ALL IN THE CAB.
The truck:
The first system that was in the truck was a Fi Bl 12 D1 running on a Powerbass ASA1500.1 at 2 ohms (didn't have the electrical to back it at 0.5 ohms, and I also didn't believe the amp would do 0.5 ohms at the time). SQ was good, got decently loud for a first system by doing a 137.5 at 40 hz. Box was 2.3 cubes net with a 3" aero tuned to 32 hz. That was back when I thought I was supposed to follow manufacturing specs...
Once I had that box, I wanted to dabble in fiberglass a little, so I built a set of kick panels to hold some PG RsD6.5 components. Turned out great for my first fiberglass project and I still have them in my truck 7 years later.
After that, I wanted to try something a little different. So i ordered an IA Death Penalty 12 when they were having their sale (was $340 shipped). Of course, the DP wouldn't fit in the box I had so I went a little crazy and did a fiberglass box. The frame of the box was wood, and I stretched fleece over the whole front. This was the 2nd thing I ever made with fiberglass and I think it turned out pretty good. Box was 2.5 cubes net with a 6" aero tuned to 36 hz. Highest score I did was a 140.0 at 41 hz, and I actually took home 3rd at the 2009 dB Drag World Finals in Amateur Psychlone division with this setup!
After a while I was bored with this setup and wanted to get louder, so I went to a center console build. The DP ripped it's surround a few months after owning it, so I reconed it and sold it to buy a 2009 Fi Bl 12. At this point I bought a Stinger SP1700 for $50 (stereo shop had no idea what they had). This setup was good for a 141.6 at 42 hz. Sounded great on most music but didn't get very low.
Then I finally made the switch to something other than a single 12 setup. I ended up trading my Fi a couple of years later for a pair of BNIB DD 1510's. I built 2 boxes for the 10's. The first box I built only did a 139.9, but my second box did a 143.4 at 41 hz and a 141.2 at 24 hz! This was so far the best sounding setup I ever had. But that was about to change with my latest build.
Once I had the 10's I wanted some louder mids and highs. So I set out to build a set of fiberglass door pods for each door to house an 8" mid range driver and a bullet tweeter. These panels have about 8 hours total in built time. Came out amazing. The mids are PPI 8" pro drivers and the bullets are AQ.
And all of this has led me to what's in my truck now. I'm sure with these pictures you'll recognize that I am the one who tested the IAD prototypes. The first amp i had after the PB was a PA BB2400.1 which was a huge piece of crap. Clipped signal at all volumes. lots of power, but not very clean. Anyway, I actually fit a single 15" sub behind the seat of my truck, and it's still quite comfortable to sit in. Box ended up being 3.7 cubes net tuned to 39 hz. Highest number to date is a 148.0 on a Massive audio 3K. To handle the power and to be able to add a 3rd battery again later I built a distribution center out of 1/2" thick aluminum stock. The middle 3 bolts on each bar are drilled and tapped for 5/16" bolts which are the audio standard for ring terminals of any size.
Also, my current sub is a production model IAD Reign 15. Rated at 1kw rms and takes the Massive 3k like a champ.
If anyone is in or around OK, come by the MWSPL show in Guthrie on the 5th of May. I'll be there giving out demos to anyone who wants to hear the truck. Hope you enjoyed the build!
Old 04-24-2013, 04:59 PM
richdog102's Avatar
Handing out Pimp slaps!!!
0/11 ssssss925
that first design is hella nice.....
People are always tough sitting behind their computer but are bitches in person...
Old 04-24-2013, 05:03 PM
0/11 sssss1046
Thank you! Could have done a better carpet job, but that was the first sub box I EVER built. Haha.
Old 04-24-2013, 05:28 PM
zone6teddy's Avatar
0/11 ssssss144
Nice man... I'm Chris the guy from FB
I felt like kickin it "OL SKOOL" soooo...
Old 04-24-2013, 05:32 PM
0/11 sssss1046
Good to see you on here. As you can see, I've had some time to mess with optimized single cab boxes. Haha.
Old 04-24-2013, 06:15 PM
zone6teddy's Avatar
0/11 ssssss144
Dude I'm talking with my buddy trying to work up a design for the console now lol...
Old 06-09-2013, 08:29 PM
0/11 ssssss192
Big jcc told me to look up ur build log we have the same truck mines even white only difference is my trucks 4x4 and lifted lil bit
Old 06-09-2013, 09:42 PM
skinnyg's Avatar
0/11 ssssss828
You may do better with like 4 or 6 8s and a ton of power. With the extra motors you can spread the power out mor. Get a bed tool box and stick you amps and batts in it to save room. Also pretty sure you can get a battery tray for a 2nd battery cause the diesel trucks had one factory. Did you get a bigger alt? You can get a 160a alt from a early 2000s durango with a 360, fire truck package. I run one on my 96 intrepid and my buddy on his jeep 4.0, you 'may' just have to change the 2 wire field plug, but on yours it may just plug in. Search Car-Part.com--Used Auto Parts Market if your local yards don't have any, or get a reman from napa. I have gotten 2 for $50 each, they are nippendenso alts so they are quality, I don't mind getting used.
With 2 agm and a 160a you should be able to do 2000w no problem, you may even be able to fit 2 G31s under the hood, then put your amps under the seat, may not need a toolbox
Like what you are doing here with the single cab, good work!
Sent from my Kindle Fire
Old 06-09-2013, 10:01 PM
0/11 ssssss192
oh yea my bad my trucks long bed to yours is short miles.
TEAM DYNAMIC BASS
TEAM UNLIMITED EXCURSION
TEAM CACO
Old 06-09-2013, 10:15 PM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
My buddy is doing a 144ish in his standard cab S10 on 1k.. but doesn't play low uploadfromtaptalk1370830518444.jpg
Sent from my DROID RAZR using Xparent BlueTapatalk 2
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Solo x 18 in a single cab C-LOS Enclosure Discussion & Design Construction Help 11 08-20-2012 02:14 PM
2 SA 10's in a single cab Miles Enclosure Discussion & Design Construction Help 12 10-04-2011 03:59 PM
single cab s10 pokerchip11 General Car Audio Discussion & Questions 2 09-04-2011 08:32 PM
single cab bass? xkryptonitex General Car Audio Discussion & Questions 15 08-01-2010 12:11 AM
Loud Single Cab? null_void General Car Audio Discussion & Questions 32 03-11-2009 02:48 AM
