2000 honda civic build - Car Audio Classifieds!
Old 04-29-2013, 10:05 PM
ReaLBallA's Avatar
0/11 ssssss150
Default 2000 honda civic build
Okay so here's what I'm working with:
2 soundqubed 2200s
2 soundqubed hdc3 12s
2 runs of 0 gauge welding cable
Tenney 300 amp alt
2 powerware 102 ah batts. Will add another if need be. Amps will be strapped at 2 ohm
Box is 5.9 cubes tuned to 34 hz
I have everything right now except for one of the amps and one of the batts.
Probably gonna seal it off as well. Port and subs firing forward. What you guys think? I'm going for some decent hairtricks and hopefully gonna break 150. Hopefully Anton miller and some other trunk kings will chime in and give me some tips and opinions. Thanks or looking guys
Old 04-29-2013, 10:22 PM
Ajax_6154's Avatar
i want more bigger db's
0/11 sssss2369
at first glance box seems rather big but then again ive never run AQ subs.
Vehicle: 2011 VW GTI Autobahn
Deadning: 50sq ft of AT 60, Front Stage: CCX65 on a 1000c4, Sub: Eminent Audio EA1000 10's in 4.9ft3 at 35hz on a BC3500d at 1ohm
i dont like 12's they cant hit the lows like 10's
Old 04-29-2013, 10:24 PM
ReaLBallA's Avatar
0/11 ssssss150
Mine love it. I wish I had tuned higher though. But I can't complain 28 hz it's loud!!
Old 04-30-2013, 06:16 PM
bass addict
0/11 ssssss331
any pics??
Old 04-30-2013, 06:17 PM
Skip01's Avatar
Ladies MAN
0/11 sssss5551
Yeh that box is close too 2x too big
Youtube VIDz :
Old 04-30-2013, 06:45 PM
0/11 ssssss133
If that box is gross he's about right.
The hdc3 is known for liking a biiiiiiigggg box.
Old 04-30-2013, 06:50 PM
Mr.G6's Avatar
0/11 sssss4614
Exactly...
Aq's suggested box sucks soooo badly
Personally I think 5.5ish cubes net is good
2000 Gmc Sonoma ext cab
Honda civic build with two 12" z v4's on 7000 watts! myjaja (Sundown Audio) 156 03-02-2016 11:41 PM
2000 honda accord trunk build kevmoney265 Enclosure Discussion & Design Construction Help 0 02-16-2013 10:35 PM
Honda Civic build 1dman Build Logs 10 01-21-2013 03:21 PM
1995 Honda Civic coupe 4th order wall build Russla Build Logs 14 07-27-2012 06:18 PM
First build: 89 Honda Civic Hatch (2 18s + sundown 3500) Vasilios Build Logs 56 09-07-2010 06:21 PM
