Enclosure Build for single 15" - Car Audio Classifieds!
Old 08-07-2009, 08:08 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
Default Enclosure Build for single 15"
My internet's been so crappy the last day and a half I couldnt get on to upload this build...but here it is. The specs are less than optimal due to space constraints though.
Specs come to:
-3.16 cubes
-34.5hz tuning
-46.5 sq inches of port area
Onward:
Louder. Lower.
Team Tupperware
Old 08-09-2009, 06:12 PM
0/11 sssssss22
dude that is SICK! How did you put the groove in the wood on the sides to make the carpet tuck in so good? I've seen it on alot of boxes but can't figure it out
Old 08-09-2009, 06:14 PM
0/11 sssssss22
the 8th and 10th pics are the views I am talking about.
Old 08-09-2009, 11:46 PM
0/11 sssss8346
Thanks. And you set the fence on the table saw approx 1/8" shorter than the width of the piece you want to do it to, then lower the blade so that it'll only cut 1/3 or so of the way through the board (this groove is called a 'rabbet'), makes carpeting pretty darn easy and clean.
Louder. Lower.
Team Tupperware
Enclosure Build: 15" for Matt Pioneer~Saturn Build Logs 21 07-24-2009 01:52 AM
Enclosure Build for Koon's single 15 Pioneer~Saturn Build Logs 46 07-21-2009 10:36 PM
My First Enclosure Build s Beatz Build Logs 13 03-16-2009 11:01 AM
Dual 12", Sealed Enclosure Build Pioneer~Saturn Build Logs 2 03-06-2009 05:45 PM
Kerfed Enclosure Build for 10" Solo-X Pioneer~Saturn Build Logs 11 03-06-2009 01:10 PM
