truebassjunkies new build log - Car Audio Classifieds!
Old 06-09-2013, 04:29 PM
truebassjunkie777's Avatar
Team Bad Intentions
0/11 ssssss632
Default truebassjunkies new build log
I'm getting ready for my new build. I just got my sub back from PSI and it looks amazing! Concept csp motor with 15" Ti basket, quad spaced spider, triple sewn leads, 8 gauge ofc direct leads, HD cone, and carbon dust cap. powered by my SAZ-3000 wired to .8. in a trunk wall with a 8" aeroport. i hope to get some decent numbers from it. this build is gonna take a couple months so i will be adding pics as i go.
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
Old 06-09-2013, 04:30 PM
Team Bad Intentions
0/11 ssssss632
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
Old 06-09-2013, 04:31 PM
Team Bad Intentions
0/11 ssssss632
I plan on getting a second XP3000. this is going in my 2011 suzuki kizashi
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
Old 06-29-2013, 11:34 PM
Team Bad Intentions
0/11 ssssss632
here are some updated pics of the build so far. all top choice birch ply. 1 gallon of resin. so on.
glued the baffle
test fitting
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
Old 06-29-2013, 11:35 PM
Team Bad Intentions
0/11 ssssss632
dont mind the crappy fatmat in the trunk i know its junk and plan on going over it with a better product. it has been in there a while
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
Old 06-29-2013, 11:38 PM
Team Bad Intentions
0/11 ssssss632
got the 45s fitted
2 4" PSP ports
test fitting the sub in the baffle
Knu 8awg ofc speaker cable
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
Old 06-29-2013, 11:41 PM
Team Bad Intentions
0/11 ssssss632
me and chris rittman testing the baffle fitment.
i will be foaming this is then adding pretty trim panels
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
Old 06-30-2013, 08:30 AM
0/11 ssssss231
Beautiful sub! Should get nasty with that SAZ. Cant wait to see the finished build.
The Following User Says Thank You to SubbinNCali For This Useful Post:
truebassjunkie777 (06-30-2013)
Old 06-30-2013, 08:35 AM
Mr.G6's Avatar
0/11 sssss4614
Remove the oldfatmat before putting something else down
Does no good if that 1st layer decides to peel off
2000 Gmc Sonoma ext cab
Old 06-30-2013, 03:23 PM
Team Bad Intentions
0/11 ssssss632
I will remove whats peeling. Most of it will not come off lol
2 SQ HDC3 10s
2 XS Power XP3000s
All sky high OFC
sundown 3000
Sundown 125.2
build log for the gf mcmuffin Build Logs 7 10-27-2011 09:21 AM
This is my first build log! Bradleyj0808 Build Logs 53 03-31-2011 10:40 AM
((Sa-15 build log)) Justin Team NWSPL 11 02-15-2011 12:35 AM
SPL_II's Team CACO Build Log <--- First real Build! SPL_II Build Logs 123 09-23-2010 08:44 PM
my new to be build log. what else do i need snoopysnooper Off Topic Chat 1 12-17-2009 09:37 PM
