Infinite Baffle 07' Civic EX build log - Car Audio Classifieds!
Old 07-08-2013, 06:03 PM
0/11 ssssss276
Default Infinite Baffle 07' Civic EX build log
My brother came to me a few weeks ago wanting 98Civic and I to plan/design/build his next system. Last time he had a dealer do his install and in all honesty. He wasted his money. I have a lot of respect for the installer as I usually have some nice discussions with him.
Anyway onto some pics:
2007 Civic EX Coupe
The wonderful 1.8l R18 engine
We should be able to fit at least a G34 AGM in. Maybe a G31 (we will try and fit one, G34 is a fallback)
Ya that's bare wire
First on the list is doing the big 3
We will be using 1/0 Tinned CCA power wire courtesy of Lyfer. Thanks man, couldn't beat the price. We will be running a negative lead off the alt bracket to negative as well (over kill for him as he wouldn't be pushing to much power anyway)
Also we will run both positive and negative to the rear. Overkill, yes. The idea of the build is efficiency so doing the overkill should help ease the stress on the electrical.
Most cases we will be running either a G31 or G34 Diehard Platnium AGM battery up front.
Source unit:
Right now we are looking at getting the Pioneer 80PRS. He isn't going to run active but you can't really beat the price/feature of the unit. I will have a discussion with him and see if he would maybe like doing a double din (non-navi).
Speakers (all around):
As of right now we are looking at getting Tantric HD 6.5 component set for the fronts and their Coaxial set for the rear.
Amps:
4 Channel:
We are running a PPI900.4 to push the fronts and rears
Mono:
IDK atm. Look bellow for sub stage drivers and I'm open to suggestions.
Sub Stage:
We always wanted to try IB and with my brothers limited space he is willing to part with IB will be perfect for him.
His requirements are decent SQ (IB is notorious for really good SQ) and the ability to get loud when he needs it to.
We decided on doing two 12" Fi IB3 single 2 drivers. These should be able to push some air with 60mm peak to peak xmax.
These are rated at 500W RMS so we need at least 1K @ 1 ohm. OPEN for suggestions.
This will be a slow build but should be killer when done.
Old 07-08-2013, 06:31 PM
0/11 sssssss98
group 34 fits remove the plastic battery tray and get new tie downs.
Where you @ beckerson?
Old 07-08-2013, 06:37 PM
0/11 ssssss276
Oh I know G34 fits. I shoved a G34 in my Civic Si. Now its back in the rear as my intake takes up that spot. He has slightly more room so maybe a G31. We will test and see if we can squeeze one in.
about 20 min West from Wooster, Ohio
Old 07-09-2013, 06:50 PM
0/11 sssss1122
Feedback Score: 23 reviews
I am using two FI Audio IB315 on a Sundown 1500d v.3. They are power hungry subs. I wouldn't use an amp with less output.
The IB315's have a boosted low end thanks to their high qts and our small trunks. Their response peaks around 31hz and falls off hard after 60hz (your install maybe slightly different but I would expect similar results).
You are going to need a solid midbas install to get these subs to blend well with the front stage. Either that or some cuts in the EQ to tame them which will cost you some ouptut.
Pros : no enclosure, heavy bottom end 20-30hz is fun
Cons : you can get way more output with smaller subs in a ported enclosure
Old 07-09-2013, 07:14 PM
0/11 ssssss276
Yep his space requirements wouldn't leave much for a HO setup anyway so IB was the way to go. The Tantric Component set has a strong midbass presence (heard them in a car environment) so don't see them having issues with blending with the sub. I actually had to cut the midrange/low end as they really favor the low end.
Do not use infinite baffle? Nik592 General Car Audio Discussion & Questions 6 01-14-2012 05:34 PM
Infinite Baffle PhishHead General Car Audio Discussion & Questions 4 09-13-2010 11:17 AM
05' BMW M3 Build - Infinite Baffle - PSI 10" + JL 1000/1 MikeyB Build Logs 21 08-30-2010 12:30 PM
infinite baffle psychoacoustics General Home Audio/Video 14 07-22-2009 10:05 AM
infinite baffle help korey_hofer Enclosure Discussion & Design Construction Help 22 07-09-2009 01:09 AM
