another motor build...RE-NEO-SE - Car Audio Classifieds!
Old 07-11-2013, 09:41 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Default another motor build...RE-NEO-SE
Ill be posting up the pics of what's up
Didn't take pictures of the mangled motor before I cleaned it up though... had alot of old ferrite stuck to the plates that was fun to take off
Neo is n45 with poles located on the 1/2"x1/2" faces... 68 pounds of pull per end x 10 links
Currently, the bottom plate has the neo on it and im awaiting cure so I can toss the top plate on... hoping like hell there's no small imperfections that'll crack pillars when I apply the plate
Thoughts, ideas etc welcome
Before it comes up, im still working on what id like to do for the cooling (ull c in pictures what I mean)
Updates soon...
all the pics from this thread
Next to a quarter
little tip, glue doesn't stick to smooth neo
Shim...
Snug as possible..the top of the shim isn't the shim, just structural
Set points for shim...u can see the actual shim precision here
Repeat but nice to see...
OLD basket
NEW basket
OLD surround
NEW surround
The Following 3 Users Say Thank You to Jeffhulbert50 For This Useful Post:
Haelmuscle (06-25-2014), iamsonic (07-12-2013), theFiverMan (07-11-2013)
Old 07-11-2013, 10:45 PM
Authorized Vendor
0/11 ssss14115
Damn, that ass.....
Will post more pictures when im not sleeping ha
art1618 (07-11-2013)
Old 07-11-2013, 11:45 PM
Authorized Vendor
0/11 ssss14115
F'it, ill post the pics then bedski...
Next to a quarter
Shim...
Old 07-12-2013, 12:00 AM
0/11 ssss31258
why didn't you make them equidistant from the gap? {I see the square pattern you made but it doesn't make sense to me}
Old 07-12-2013, 05:56 AM
Authorized Vendor
0/11 ssss14115
I modeled it in FEMM and I liked the results.... the original intent was partial structural support accrosed the plate and bottom between the mounting surface but also having the saturation at the outter edges to allow the flux to go up both the inner and outter edges to charge the plate evenly
The pole orientation vs the stock form of this motor shouldn't differ.... the sides of the poles are shielded since the orientation of the poles are on the ends
Old 07-12-2013, 06:09 AM
0/11 ssss31258
that's neat... and strange.
I'd like to see a radiation image representation of the final result.
good stuff man. nice work also
btw, how does the weight compare to the original? finished weight vs original weight
Old 07-12-2013, 06:13 AM
Authorized Vendor
0/11 ssss14115
Its like a feather... shim will be out tonight to check for gap tolerance...it looks sexy on a 12w7 basket
Old 07-12-2013, 06:26 AM
0/11 ssss31258
sweet.
those are some very strong neo magnets. do they even need glue?
Old 07-12-2013, 06:39 AM
Authorized Vendor
0/11 ssss14115
sweet.
There's a good chance they could stay with out glue, but I also love overkill...also the neo links have a factory tolerance of. 002" +/- and the top plates surface was pitted so the glue will fill the voids (if any) and eliminate any risk of a week joint
Old 07-12-2013, 07:14 AM
0/11 ssss31258
I am curious if the plates exhibit polar radiation now. {top plate positive, bottom plate negative}
they should and I know that's the goal. I'm not saying they don't or won't.
did the neo magnets have a preference as to which end liked which plate to begin with? kinda seems like if they did, then they should be flipped over and fought together.
WTB: TC Sounds Neo 3HP motor (fat, thin slug motor) bergend2 Wanting to Buy (WTB) 5 09-04-2013 12:44 PM
WTT: BNIB TC Sounds Pro 5100 Neo Radial Motor for TC-5400/Ultra or 2010 TSNS Motor zeuslicious Car Audio Trader (WTT) 40 06-19-2013 11:32 AM
Pillow's Neo motor build up. Pillow (Fix My Speaker) 7 11-17-2010 03:05 PM
[NLFT]TC Sounds Neo Motor For Ceramic Motor/Motors SundownAudioNY Car Audio Trader (WTT) 0 08-22-2009 08:07 AM
Re: DD Z NEO motor F/S bones22 Recycle Bin 0 08-12-2008 01:31 AM
