1st 4th order attempt - Car Audio Classifieds!
Old 07-29-2013, 12:21 AM
0/11 ssssss697
Default 1st 4th order attempt
Attempted my first 4th order, orion hcca 12 in a 1:2.4 ratio box, with 80 sq in of port. This is my second attempted at kerfing, but it turned out alright. Ported side is tuned to 50 hz. Any input on how these specs will work? Is it better to fire sub forward toward port or to the side?
Old 07-29-2013, 12:23 AM
0/11 ssssss542
I did magnet on ported side so I could get better cooling on the coil. should be pretty musical and hit anything 30-34hz and up well.
Old 07-29-2013, 12:26 AM
0/11 ssssss697
Yea it's not working to upload all my pics, but I have magnet on ported side. Any tips on making removable panel?
Old 07-29-2013, 12:27 AM
0/11 ssssss542
I sealed mine in never coming apart in one piece lol
Old 07-29-2013, 01:35 PM
0/11 ssssss697
I should of maybe put this in enclosure design discussion... Any more input?
Old 07-29-2013, 01:41 PM
Josh Wahlie's Avatar
< Pic from my build log!
0/11 sssss3196
Just don't glue the top piece down and use a gasket
Custom Box Builder (Ships all over the USA)
Shok Industries Dealer
Old 07-29-2013, 01:43 PM
0/11 sssss2148
Feedback Score: 26 reviews
How about weather stripping on the side of the panel thats on top? Or in that pic, the panel that the cone of the subwoofer is firing towards. Could use weather stripping between the piece right there instead of glue so you matain a decent seal and can still remove it if you need to service the sub.
Old 07-30-2013, 08:15 AM
0/11 ssssss697
I was planning on doing the panel the sub is firing against. If the top removed, I still wouldn't have enough space to remove sub. Getting some terminals today and rod for bracing!
1st try/attempt at door pods sthrnbumpn Sound Deadening & Fabrication 4 06-12-2012 07:33 PM
1st attempt at DIY tweeter orbs. TaylorFade General Car Audio Discussion & Questions 6 12-23-2011 11:28 PM
1st Box Build (4th order) crownvicon26's General Car Audio Discussion & Questions 45 09-15-2011 06:46 PM
1st Attempt...... KickerCobalt Off Topic Chat 13 05-15-2010 04:58 PM
