slow monte carlo build - Car Audio Classifieds!
Old 08-12-2013, 01:24 AM
0/11 sssssss83
Default slow monte carlo build
Hi everyone i have a 2001 monte carlo ss i want to put my subs in. i have 2 of the newer poweracoustik mofos with a 2.5" voice coil. ive built a few different ported boxs but was thinking of doing a 4th or 6th order. pretty much the best enclosure i can fit in there. i just picked up 2 sheets of mdf today and i plan on starting tomarrow. any ideas would be awesome thanks
Old 08-12-2013, 05:27 AM
0/11 sssss1027
Off the top of my head for ideas I guess I would have to say first get rid of those subs! Yuk!
Old 08-12-2013, 07:06 AM
Stress tester
0/11 sssssss63
Sounds pretty close to what I'm thinking about doing as well, in the same vehicle, with 2 SSA XCon 12's That's going to require a whole lot of room though, and I'm not sure I can give up that kind of space.
I'm looking at a 6th order, 5 cu/f @ 28 hz + 2 cu/f @ 48 hz. Every 4th order I model in winisd looks way too peaky. Although, that's modeling the xcons, not the mofos, so your mileage may vary.
Good luck, I'm looking forward to seeing a build log!
Old 08-19-2013, 04:19 PM
0/11 sssssss83
welp trying to model the mofos but i cant find half the driver data
Old 08-21-2013, 06:27 AM
Stress tester
0/11 sssssss63
PowerAcoustik - Subwoofers - MOFO-122X
Old 08-21-2013, 08:01 AM
0/11 sssss1968
Feedback Score: 25 reviews
Check out my build log guys
2007 monte Carlo Ls build
I'm telling you from my personal experience if your doing a 4th/6th order the box will have to be built in the trunk. That being said its a pain in the ass. Can it be done yea I'm sure it can but if you plan on doing a high powered system such as mine. Your going to need room for batteries and amps. Is it worth it to do power acoustics in a 4yh/6th order no I don think so. But you may see differently. If wanting to do any kind of band pass do a 4th
2007 monte carlo
New build hopefully starting soon.
TEAM XS POWER TEAM DC AUDIO
2007 monte Carlo Ls build fosgatefeind Build Logs 135 07-09-2013 08:58 PM
2007 monte carlo Ls build fosgatefeind Uninterrupted Build Logs 3 11-30-2012 10:43 PM
2 15inch zv3 trunk build in monte carlo 04montecarlo Enclosure Discussion & Design Construction Help 42 11-13-2012 07:15 PM
My 2001 Monte Carlo SS/HS build Blazed SS Member Rides & System Pictures 30 11-08-2011 04:25 PM
'02 Monte Carlo ss help!!! peytonbradford General Car Audio Discussion & Questions 1 02-28-2011 06:35 PM
