1993 Lincoln Continental - Car Audio Classifieds!
Old 08-19-2009, 05:39 PM
0/11 sssss1741
Default 1993 Lincoln Continental
Im copying/pasting this from the uninterupted build log. Like i said, this car is going to take some time but will eventually be putting some nice stuff into it. Just thought id post it here too to get some feedback, and ill keep the other thread there so i can have the updates with no other stuff to look through. So hope to get some feedback in this thread. I know its not much special right now, but eventually ill be putting better stuff into it.
I just bought a 1993 Lincoln Continental. It has a blown motor which i am going to swap out for another. I dont have the donor yet, hopefully soon ill have it. Other than the motor the car appears to be in very nice condition for the most part. And i got it for a good price so im happy with it. This build log will be for both the system build up, and the motor swap. So will have pics of both things. I do not have the complete system for the car yet. I do have the two DD 9515's that will go in it, but will wait to get an amp. This will be slowly updated due to not having all pieces yet.
Ill start off with some pics of the car. Not a huge fan of the color, but the body is nice with very little rust. Sorry not the best pics, it was just after i got it.
Im hoping it looks decent with tinted windows, with the color it has. Dont think ill be able to afford getting it painted so im stuck with the color for now.
Old 08-19-2009, 05:40 PM
0/11 sssss1741
For the temporary deck it will just have a sony..
Here is the opening for the radio, with the RCA's and remote wire ready.
Since im only needing 3 wires hooked up, im not going to buy a harness for the car, just splice into the 3 power wires that i need. But i do still gotta splice into the power antenna wire, and dimmer wire i want to use also, which isnt done yet but i will eventually.
0/11 sssss1741
I have the power wires and stuff sitting around, so i figure i may as well run that for now, tho the car doesnt run, it will.
The 1/0 Knu KLMX power wire
Through the firewall
Running it under the carpet
The wire is ran and un-noticable I know, its dirty. Not worth cleaning while its being worked on right now cuz it will get the same way by the time its driven anyways.
And finally coming through the trunk
The deck is in and looks decent. It would look alot better with a trim ring around the radio, but i dont have one, and im pretty sure it wouldnt fit with the cars trim around the radio either. The sweet thing is the deck has the tilt face so i can angle it nicely, since the dash in these cars are pointed downwards. When i upgrade decks, angle face is definitly a must have on the specs list now.
0/11 sssss1741
This is the temporary 4 channel. I know, its a piece of shit wal mart amp. I honestly dont care tho. It amplifies my speakers, and does good for the cheap thing it is. And im not after SQ right now anyways, nor do i have good speakers, So does a great job for what it is and what its being used for.
I left the plastic cover on top from when it was new, and just now took it off. It looks brand new now ha.. I know the wiring is a big mess. I wont get that cleaned up til i figure out exactly how the trunk set up will be, as far as where ill mount the amps, subs, distro blocks etc.
Old 08-19-2009, 05:41 PM
0/11 sssss1741
I tore the engine apart in the car, in hopes of just needing head gaskets. Since these motors are all known to blow head gaskets, unless they got the new better head gaskets from ford. Well, the motor doesnt look great so im gona replace it instead. Here are a couple pics of the motor.. As you can tell it doesnt look good. Will be posting more pics once i get the donor car/motor and do the swap.
Old 08-24-2009, 02:24 AM
0/11 sssss1741
No interest for my crappy "build" ? Haha.. I got a donor car for the motor, hope it works out good. I heard the motor run before buying it, the trans was bad in that car. Just hope the motor stays together for a good amount of time, and hope the trans is good in my car like they said it was. I can see a good amount of rust on the oil pan on the new motor, which i read is one of the many common problems for the ford 3.8 motors/cars. So ill be putting the oil pan from the old motor on it as im pretty sure its in good shape, or ill get a new one or something.
This is going to be quite the ***** and a ton of work swapping motor seeing as i have to drop the motor through the bottom of the car which isnt fun if you dont have a big lift like a shop has.
Once i get the motor dropped in my car, ill clean it up good and take some new pics. Ill prolly get some pics during the motor swap too. Cant wait to get a real system in it tho.
Old 08-24-2009, 02:47 AM
looks like alot of work ahead of you
Old 08-24-2009, 02:51 AM
0/11 sssss1741
A ton of work. All the work is in the motor swap tho. Its so much work doing a front wheel drive car motor swap, i can do a rear wheel no problem.. Gona take me a while to get it swapped over im sure. But thats first on the list to get done obviously. Cant wait to get the car going tho.
Old 08-24-2009, 02:55 AM
obrien202's Avatar
I race dertscooters
0/11 sssss4142
Feedback Score: 26 reviews
lots o work u need to buy my 15's i think that should wrap the build up
may music always make you happy even if life does not
Old 08-24-2009, 02:59 AM
0/11 sssss1741
Nope, i have a pair of 9515d's.. I need amps
Tags
9515d, build, digital designs, lincoln
1993 Lincoln Continental System/Motor swap westman995 Uninterrupted Build Logs 12 09-05-2009 12:20 AM
Licoln Continental Trunk westman995 General Car Audio Discussion & Questions 12 08-14-2009 02:05 AM
[SOLD]1993 Cadillac Seville STS for sale, w/20" rims bangin hoe Miscellaneous Stuff For Sale 0 02-07-2009 01:04 PM
2005 Lincoln LS box jigga jatt Box Requests 13 10-03-2008 08:34 PM
Rim request for Lincoln LS SPY Miscellaneous Stuff For Sale 12 09-16-2008 04:01 PM
