2008 Hyundai Tiburon Build Log - Car Audio Classifieds!
Old 08-20-2009, 12:08 AM
TheJesus's Avatar
Yawning
0/11 sssss1921
Default 2008 Hyundai Tiburon Build Log
First off, this won't be starting until May/June, but I just wanted to go ahead and open a topic .
I have nothing particularly set yet, other than I plan to do 2x 15"s in a ported box that will be roughly 8ft^3. The 15s will more than likely be DC LVL4 XLs or maybe LVL5 (not sure I need the extra power handling for the extra money :P). The build will be less than $4k. It will be in a fiberglass enclosure by HHR_Ed. The amps may be DC, but I'm seeing who else I can touch base with to do some comparisons. I have no idea about the batteries I'll need, but according to Mazda6i07 I need 4 batteries for the amps, which is about right. I'll be getting a 250 amp alternator from Mechman (Rhino series I think?). The wiring will be Headshok's 1/0 competition grade. The head unit will be the stock double-din w/ GPS Kenwood from Hyundai mainly because it looks quite slick and it'll save money . Organized summary below .
Subs:
2x Lvl4xl or Lvl5 DC 15"
Alternator:
Mechman 250 Amp
Enclosure:
~8FT.^3
Fiberglass by HHR_Ed
Wiring:
Power/Ground - Headshok's Competition 1/0 ga.
Speaker wire - Undecided
Amps:
2x 2.5kW+ RMS - Undecided (DC's 3000.1 or something similar)
Batteries:
4x Amp Batteries (XSPower maybe?)
1x Yellowtop (to replace main)
Head Unit:
Stock Kenwood GPS Double-din
Budget:
~$4000
If anyone has recommendations for the things I am undecided on, I would love to hear them The picture below is what the trunk looks like (basically) and the projected arrangement of things .
The batteries will be double stacked using some form of brackets, and the amps will be laying flat or sideways mounted against the rear of the car. Given I haven't quite decided fully on everything :P.
Thanks!
I used to have that walled Challenger, then it got totaled...
2015 IASCA Welterweight Champion and Record Holder - 156.0 Avg (No door blockers)
2016 IASCA Welterweight Record Holder - 157.7 Avg (Door blockers used)
Team Sundown Audio & Fullriver Faction Member
Old 08-20-2009, 12:12 AM
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
Cooling on amps?
Old 08-20-2009, 04:51 AM
TheJesus's Avatar
Yawning
0/11 sssss1921
Originally Posted by grimreper912003 View Post
Cooling on amps?
One of the problems I have to deal with, I was thinking putting some small fans to circulate the air, or do some liquid cooling (it would look crazy )
Old 08-20-2009, 05:01 AM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
2.5kw would treat the xl's nicely assuming you know what you're doing.
Last edited by Scapelli21; 08-20-2009 at 05:03 AM. Reason: nvm, my dvmba$$ just re-read lol
Old 08-20-2009, 05:06 AM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Plus, I don't think you'll NEED 4 batts persay. 2 D3100's or hc2800's could do nicely also.
Old 08-20-2009, 05:08 AM
Scapelli21's Avatar
I <3 ( . )( . )'s
0/11 sssss3108
Plus how much space is in one of these vehicles? 5-6kw takes up quite a bit of space with all the batts and wire necessary.
Old 08-20-2009, 05:38 AM
C3 Customs's Avatar
0/11 sssss2446
Could always go with a Stetsom 5k2D 1 ohm version, then you only need 1 amp
WRMS Power (1 ohm) to 12.6 V: 5.475 Watts
WRMS Power (2 ohms) to 12.6 V: 3.600 Watts
WRMS power (4 ohms) to 12.6 V: 1.985 Watts
We provide our customers the only scientific approach to musical enjoyment. ."-C3 Customs
Mobile: Bravox Audio - Stetsom - Arc Audio - Second Skin - RE Audio - Clarion - DLS - German Maestro-Bazooka
Home: Onkyo - BSA Audio - Denon - Sony - Niles Audio - DLS - Sherbourn-Velodyne-Jamo
Computer: AudioEngine
832.695.3513
Old 08-20-2009, 07:04 AM
0/11 sssssss67
Matt, Hit me up when you got some time so I can tell you about some 15" options
Old 08-20-2009, 11:29 AM
0/11 sssss6190
Personaly I would do 2 12"s or 1 15". I think you will be more happy in the long run. Proper Box > cone area.
Old 08-20-2009, 11:40 PM
TheJesus's Avatar
Yawning
0/11 sssss1921
All good suggestions . I'll address each:
Scapelli21 - 1. I thought 2.5 or 3kw sounded about right for the XLs. 2. Wasn't sure if I NEEDED them, I'll have to get some more opinions on it . 3. There's not a ton of space which is one of the issues I'll be facing, however I think it should accommodate everything perfectly (screw you luggage :P).
C3 Customs - If I did go that amp and the XLs, I'd have to make sure I'm only giving it the 12.6 volts otherwise I might wear them down quickly, but if I just got the LVL5s it would be perfect , good suggestion .
PSI Smalls - I got your number, will do .
grimreper912003 - Well, I think it would be easier to do those options, but A. I like a challenge and B. I like the sight of 2x 15"s :P. I think the box will be exactly what I need.
Anybody else got any ideas?
2003 Tiburon Build RidnClean Build Logs 17 11-21-2009 04:27 AM
Just Showin' Off for Toys for Tots 2008 ~ Huntsville AL ~ 11-15-2008 CACO's Car Show Bot Car Show Feeds 0 10-27-2008 03:00 AM
Motor Sports 2008 ~ Tacoma WA ~ 11-07-2008 CACO's Car Show Bot Car Show Feeds 0 10-26-2008 03:00 AM
Triumphest 2008 ~ Stateline NV ~ 10-02-2008 Patrick Simmons Car Show Feeds 0 09-29-2008 03:05 AM
Kroozinationals 2008 ~ Huntington IN ~ 10-04-2008 Patrick Simmons Car Show Feeds 0 09-29-2008 03:05 AM
