First time welding a steel cage. Jeep Grand Cherokee c-pillar wall rebuild. - Car Audio Classifieds!
Old 11-02-2013, 08:24 AM
AudiophilesEngineering's Avatar
Mad Scientist
0/11 ssssss202
Cool First time welding a steel cage. Jeep Grand Cherokee c-pillar wall rebuild.
My first wall in the Jeep broke some stuff and water leaked in and got the wall all nasty and moldy so it had to be destroyed.
It consisted of ten entry level Audio Technix Tropo 10s on a Crescendo bc5500 and barely did 150db at 29hz.
This rebuild will be less subs and slightly more power but should be a lot louder.
This will take a while, because it is being squeezed in between my customer's builds, so be patient.
Mad Scientist
0/11 ssssss202
Cut 1/16" sheet metal to fit where the glass was in the rear side windows.
First weld ever. Yea I suck but I am getting much better. At least it is sealed up and won't leak ever again.
Body Filler.
Good enough for now =)
Old 11-02-2013, 08:25 AM
Mad Scientist
0/11 ssssss202
Starting on the cage. 1/8" thich 1"x1" square steel tubing.
Mad Scientist
0/11 ssssss202
Welded as much as I could outside of the Jeep. Welded the four pieces together inside the Jeep. Worked out very well.
Mad Scientist
0/11 ssssss202
Wired up the front battery.
Wrapped the back of the wall in white vinyl.
Welded a simple little battery tray and wired up some batts.
Pretty much have the back of the wall ready for one big ass amp.
Old 11-02-2013, 09:43 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Very nice. If it was a different model id have some power upgrades for you! Im a WJ owner myself.
Old 11-02-2013, 10:58 AM
0/11 sssss3842
not bad. 150db @ 29hz isnt terrible in my eyes. peaking that low is crazy lol.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 11-02-2013, 11:20 AM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
I agree, my jetta did a [email protected] and it is low! If i remember right a grand cherokee peaks around 50hz so its workin it for that [email protected] For first time welding id say it looks nice and is coming along nicely! Tuned in man
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 11-05-2013, 08:03 AM
Mad Scientist
0/11 ssssss202
Inside is ready to glass.
Old 11-05-2013, 02:16 PM
Mad Scientist
0/11 ssssss202
Those 1/8" gaps are due to the cage being slightly warped and the wood not lining up as they would if the cage were perfectly square. Rather annoying. They are all filled in now though.
Baffle is coming along...
Tags
18s, c-pillar, cage, jeep, wall
340 Amp Mechman alternator for jeep grand cherokee 6.1L or 5.7L jeep commander Mnorwood01 Wiring, Electrical & Other Installation Equipment 16 12-29-2012 11:09 PM
c pillar wall in a jeep Hector_509 Enclosure Discussion & Design Construction Help 1 10-14-2012 11:30 AM
2004 Jeep Grand Cherokee stilltippin863 General Car Audio Discussion & Questions 7 02-03-2012 04:33 PM
97 Jeep grand cherokee v8 parts?? law112493 General Automotive Chat 0 06-28-2011 12:30 AM
