Enclosure Build: 2 12" HDC4's, kerfed, angled, next level. - Car Audio Classifieds!
Old 12-04-2013, 08:56 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
Default Enclosure Build: 2 12" HDC4's, kerfed, angled, next level.
Alright guys, I've got another build for Wooferwarehouse.com for a pair of HDC4's that should be a bit different...
Specs come to:
-3.75 cubic feet net
-37hz tuning
-46.22 sq inches of port area
It's on the smaller-side but he'll be running a lot of power so that may not be such a bad thing.
The design:
^Mirrored the original design so the port will be on the other side
Got a good bit of the pieces cut tonight...
More tomorrow
Louder. Lower.
Team Tupperware
Old 12-04-2013, 11:12 PM
0/11 sssssss24
I can't wait to get this thing playing. Here is the hatchback it will be going into. I'm aiming for 150+
Current temporary setup until the new box is finished.
And the equipment:
2 SoundQubed HDC412's on 2 AQ 3500's
Old 12-05-2013, 03:39 AM
Beerdrnkr's Avatar
0/11 sssss1231
Nice, I have the same vehicle. Its pretty easy to get loud!
Sent from my LG-D801 using Tapatalk
Old 12-05-2013, 12:09 PM
0/11 sssssss91
what's electrical like?
Old 12-05-2013, 12:13 PM
Silver-N-black's Avatar
0/11 sssss3544
I know this box is going to turn out great.
Old 12-05-2013, 12:38 PM
0/11 sssssss24
Currently I have a 200 amp Singer alt, a d3400 up front and a d3100 in the trunk. I will be adding 1-2 more d3100's and eventually will be looking at a getting a bigger alt. Unfortunately I will have to get a custom bracket made if I want to get a bigger alt to be able to fit a bigger housing since it sits so close to the engine.
I'm thinking so. He seems to do fantastic work. I just hope the airspace and port area are enough. I'm likely inverting the subs since the HDC4 motors are massive and would take up a lot of internal volume.
Old 12-05-2013, 09:56 PM
0/11 sssss8346
Louder. Lower.
Team Tupperware
Old 12-06-2013, 12:10 AM
Brand New Members
0/11 ssssssss2
very nice! i just built a box for my new HDC412s. 3.75 net tuned to 38 right now (adjustable port). haven't done any testing yet, but i have high hopes.
Old 12-06-2013, 01:46 AM
0/11 sssssss24
Nice! Looks good man. Is the 3.75 before or after displacement of the sub? Do you happen to know how much displacement these subs take up in a box?
Old 12-06-2013, 02:28 AM
myjaja's Avatar
0/11 sssss1060
I had a pair of 12" hdc4's in a 5.9 cu ft enclosure with a 10" port tuned to 31 hz which did a 151.6 at 32 hz in a trunk of a honda accord. It was off a saz-3500 at a .25 ohm. Good times
I believe they were .18?
HU: Home stereo converted to dc
Speakers: Stock
Subs: 6 1/2 home sub
Amp: off the stereo
Wiring: extended power cord
neon lights: Christmas lights duct taped to frame
Enclosure Build: Banks' DC 12", kerfed port Pioneer~Saturn Build Logs 33 05-21-2012 05:47 PM
An enclosure for two 12" hdc4's myjaja General Car Audio Discussion & Questions 15 12-13-2011 12:50 AM
Enclosure Build: Bobby32's DD9512, kerfed port Pioneer~Saturn Build Logs 15 10-22-2009 01:11 AM
Kerfed Port Enclosure Build For My Hdc315 twisted Build Logs 15 04-12-2009 12:06 PM
Kerfed Enclosure Build for 10" Solo-X Pioneer~Saturn Build Logs 11 03-06-2009 01:10 PM
