"the pig" ...10" woofer build - Car Audio Classifieds!
Old 12-21-2013, 03:10 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Default "the pig" ...10" woofer build
Nicknamed "the pig" due to its ridiculous size and weight, this was the next project to be given attention.
I was going to build it as a 12...but haven't owned a 10 in ages, so big as 10s a nice start
The parts-
Lazar opti 1533d motor bored out to 3.36"... triple 1" slug, 1" top plate
10 ti basket
8.5" HDD spiders, either 2 or 3
HDD leads
HDD coil
HDD cone
plane dust cap
12" basket ^
got my 10 basket, mocked up before top plate arrived
Old glue
Clean the glue off
top plate back from bumpinbuick milled and bored
Building my shim.. single cardboard tube (thick wall ) split, then patched solid to the poles OD.
Added a layer of stiff cardboard to take up most of the gaps room... then wrapped in layers of tape (1", same as top plate) to get the gap tight
Not seen, didn't take pictures...mark where the top plate will lines up with the shim, take the shim off the pole and insert it into the top plate the same as it would be removed.. I attach stoppers to keep the shim from sliding down through the plate...then apply glue to both surfaces
The shims long enough that it slides onto the pole without pulling the plate...very helpful.. then slide it down holding steady and....
Bammmm... attached....leave the shim in until its fully cures, the plate could always creep sideways and mess up the gap
beautiful glue bead
Parts should be here soon and ill update the rest...
Note - although there are alternative ways to put a top plate back on a motor, this method works well for me... hasn't me failed yet
Old 12-21-2013, 03:17 PM
Authorized Vendor
0/11 ssss14115
Old 12-21-2013, 04:14 PM
Authorized Vendor
0/11 ssss14115
Going to have this moved... I guess no one can reply in this section
graham (12-21-2013)
Old 12-21-2013, 07:29 PM
Authorized Vendor
0/11 ssss14115
Thanks sonic
Old 12-21-2013, 07:40 PM
snoopysnooper's Avatar
Awaiting Confirmation
0/11 sssss4665
Feedback Score: 33 reviews
so sick!
2006 grand caravan
sony dsx-s210x
lanzar opti 2k
3 sundown sa8v2d4
t-line unloading at 34
juice box black cherry
Old 12-21-2013, 07:49 PM
Authorized Vendor
0/11 ssss14115
thanks, hoping to give it gobs and gobs of power
Old 12-21-2013, 08:21 PM
0/11 sssss1085
Feedback Score: 23 reviews
10" ti only has an 8.5" landing?
Old 12-21-2013, 08:42 PM
Authorized Vendor
0/11 ssss14115
Yup... same diameter as the motor
Old 12-21-2013, 09:10 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
o lawd jesus its a bass
Old 12-21-2013, 09:15 PM
Authorized Vendor
0/11 ssss14115
hey fishy fishy
WTB/WTTF 15" or 12" #1000rms @ 2ohms woofer Stubb536 Wanting to Buy (WTB) 9 03-10-2011 02:54 AM
TurBaconEpic "I'm here for my pig" Benny33 Off Topic Chat 13 11-24-2010 04:38 PM
Mid/Tweeter "cups"/"covers"/"enclosure"/"etc"??? oxsign General Car Audio Discussion & Questions 11 04-21-2010 05:29 PM
New Sundown "E" Woofer Line Sneak Preview sundownz (Sundown Audio) 28 11-25-2009 06:01 PM
