Box Build for 2 SSA Evil 18's on 2 NS-1's! - Car Audio Classifieds!
Old 01-08-2014, 12:43 AM
0/11 sssss1046
Default Box Build for 2 SSA Evil 18's on 2 NS-1's!
Got the call from someone local to build a box for his setup. He has 2 SSA Evil 18's on 2 NS-1's at 0.5 ohms a piece, with 4 XS D3100's and a Mechman 270. His current box was initially built for 4 18's (something like 18 cubes net) and stuck WAY above the window line. He wanted a box for just the 2 that he has, a lot smaller box, and something with a little "flair". Well, here it is...
Specs:
13.2 cubes net
12" Octaport
32.3 hz
Double layered all around (except sides)
Window style bracing
Bolt terminals
Bedlined outside with a fire-engine red port
Here is what I got done in a couple of hours tonight. Tomorrow I'll be fiberglassing the inside corners/braces, and finishing the outside with bedliner and paint. Tell me what y'all think!
Old 01-08-2014, 12:49 AM
0/11 ssssss457
Only 4 d3100s for 2 NS-1's at .5 each? I think he'll want 4 more if he wants to stay over 12v.........
Box is looking good though
-C2 Audio Threatcon 4 12s"
-Sk4500
-Mechman 220 alt w/ big 3; Two runs +/- to back
-Yellow top upfront, 3 batcap 2000s in rear
Old 01-08-2014, 12:54 AM
0/11 sssss1046
He hovers at about 11.5 at idle at full tilt. If he would actually rev it to 2k, I'm sure he'd be above 12.5-13.
Old 01-08-2014, 02:05 PM
0/11 sssss1046
** It's done! **
Bedliner is still wet in the pictures, so that's why it looks a little funky. Pretty happy with how it turned out. Need to get another can of bedliner to spray the inside with so it looks even better. Customer is picking it up tomorrow. Can't wait to hear this thing!
The Following User Says Thank You to Miles For This Useful Post:
Old 01-08-2014, 02:13 PM
massivespl's Avatar
0/11 sssss8409
sweet. should slammm
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 01-08-2014, 02:20 PM
0/11 sssss1046
Might be playing tomorrow afternoon or friday at the latest. Will be getting numbers Saturday.
Old 01-08-2014, 02:23 PM
0/11 sssssss79
Wow, I like it!
The Following User Says Thank You to denim For This Useful Post:
Miles (01-08-2014)
Old 01-08-2014, 03:13 PM
villeza1's Avatar
0/11 ssssss544
Originally Posted by denim View Post
Wow, I like it!
X2
2 AB 1100.1's
4 Tantric Sounds SHD 18's (PSI Recones)
4 Mechman Alternators
9 XS Power Batteries
24 Crescendo Mids/Highs
5 MB Quart Mids/High Amps
Old 01-08-2014, 03:41 PM
0/11 sssss1122
Feedback Score: 23 reviews
What are the outside dimensions on the box and what vehicle is it going in?
Old 01-08-2014, 03:52 PM
0/11 sssss1046
49x35x20. Its going in a Suburban XL.
SSA Evil Build Sencheezy Build Logs 20 12-27-2013 03:36 AM
Astro Build 4 Zv4-18's 2 Ns-1's 16volt canufeelme Build Logs 8 12-23-2013 02:56 PM
ssa evil 4" coil teamjesusbeatz General Car Audio Discussion & Questions 263 08-08-2013 08:21 PM
Ssa evil Slogging General Car Audio Discussion & Questions 19 07-02-2013 03:24 PM
Demoing The SSA Van 8 SSA ICON 18's In A 4th Order! got160s? Car Audio Videos 0 08-21-2012 04:11 PM
