1/4wave t-line box for two 8in subs - Car Audio Classifieds!
Old 01-17-2014, 05:08 PM
0/11 ssssss340
Default 1/4wave t-line box for two 8in subs
this box is for a pair of Massive Audio "Hippos" 8in
heres what i got so far.
any changes that need to be made??
subs are in about 0.6cu with 51sqin of port and port is 78in long and the tune is the fs of 41hz
Old 01-18-2014, 10:18 PM
0/11 ssssss340
4x8ft sheet of mdf
tools laid out
lines made
panels cut
mock-up
pre-drilling holes
all glued and sealed off with port painted black
testing location of led in port
led glued down and led wires ran
green led board i made screwed on and wires glued and ran in corner
Old 01-18-2014, 10:20 PM
0/11 ssssss340
will try to get off work early tomorrow to finish the speaker holes, speaker wires run, 45s, glue top on.
Old 01-19-2014, 02:00 PM
G00burr's Avatar
0/11 ssssss591
good work so far man
Old 01-19-2014, 02:33 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7527
Feedback Score: 22 reviews
needs moar 45s!
good work so far.
Old 01-19-2014, 02:39 PM
soze1's Avatar
0/11 ssssss208
looking good, interested to see how this works.
I keep looking at those hippo 8's......gonna click "buy" one of these times
Old 01-19-2014, 04:55 PM
0/11 ssssss340
Thanks guys. Look like I wont be getting off early today so tomorrow ill have to get this done.
I have 1 hippo in a 6th order and it sounds ok but I think a 4th will sound better for these.
Old 01-20-2014, 09:29 PM
0/11 ssssss340
cut out speaker holes
test fitting in my car (damn it was a tight ass fit!!)
wanted the port to be faceing the rear but it was hitting the back of the car so i have it firing forward.
now im going to break in the speakers till this weekend and drop the 45s in and glue and seal the top off
Old 01-20-2014, 09:39 PM
0/11 ssssss340
did a quick pounding with the box and its tuned a bit higher than im used to but i have to remember that these are 8in sub and not 12s or 15s.
but in my opinion so far this is sounding pretty damn good and most important LOUD.
it pounds at the tune point (41hz) and gets pretty low (25hz) and sounds good at that low but i think because the port is firing forward the low note dont have time to travel b4 it gets to me, so i think the lows COULD sound alot better if i flip the box to fire the port back.
but i know the 45s in there should make a difference in the sound and sealing off the top.
so stay tuned more to come plus videos too.
Old 01-20-2014, 09:40 PM
0/11 ssssss340
oh and this is the amp im using wired to 1ohm. (600wrms)
The Following User Says Thank You to joemon For This Useful Post:
sthrnbumpn (02-11-2014)
4th order 1/4wave t-line box for two 8in subs joemon Enclosure Discussion & Design Construction Help 7 09-19-2013 10:00 PM
WTB: Good 8in Subs Chevy_boy Wanting to Buy (WTB) 21 07-11-2013 10:09 PM
WTB: 6.5-8in SUBS treylittlefield Wanting to Buy (WTB) 19 05-04-2013 01:43 AM
DC subs and T-line box? kerontt (DC) 0 08-30-2010 01:40 PM
DD 1500 subs 8in- NEW PHOTOS INCLUDED spluvs2install 8" Subwoofers 6 12-30-2008 09:15 AM
