99 Jeep Cherokee - 4 15's C Pillar Wall - Car Audio Classifieds!
Old 01-23-2014, 05:19 PM
0/11 sssssss56
Default 99 Jeep Cherokee - 4 15's C Pillar Wall
I've been a member on a few other car audio forums but have never set up a build log on here. My vehicle is a 1999 Jeep Cherokee Sport, with the 4.0l i6. I'm a senior in highschool, and got my Jeep back when I was 15. I've been through a few systems...learning as I go. I've also lifted my Jeep 3" and thrown 31's under it, as well as a few cosmetic and mechanical additions.
My Jeep the first day I got it
Bought it bone stock except for an aftermarket Pioneer radio
My first system...installed by myself back when I was 15, going on 16 (couldn't even drive at the time haha) was 2 Kicker L5 15"s powered by 2 Crunch p2000.1 's
Next thing I did was lift it 3" and throw 31s under it. Lift kit is a full spring pack leaf springs in the back to support the extra weight from subs and boxes, and heavy duty coils in the front for if I ever add a winch bumper
As you can see...this Jeep is my daily driver, car audio build, and weekend warrior
Next I installed a Sony CDX GT650 ui, polk DXI 650s, and a Kicker ZX350.4 for my headunit and mids/highs.
Then I bedlined the lower quarters/bumpers/and fender flares with bedliner
Also painted my rims black
And bought a Yakima Megawarrior Roofrack, lightbar, and 4 KC Daylighters
Next system was about a year later. 3 SA8s wired to .67 ohms, powered by a SoundStream TX1 2600.
Next system was 2 DC m2 Level 3 18"s on 2 MB Quart ONX2000's
And that brings us to my current build... 4 Obsidian Audio OA15's powered by a Popcorn Sounds AX6000.1 with an AA 500.1 "THE FIX" board instead of the usual opti board that most came with. This is one of only 12 Popcorn Sounds amps made with the 500.1 boards.
4 OA15's
Which I then plastidipped black to go with the new all black theme
Popcorn Sounds AX6000.1 w/ AA 500.1 "THE FIX" + toolmaker duals + Knu 1/0
"THE FIX"
Aaaand all of my equipment from the past few years.
50' Sky High 1/0 OFC for runs from front to back. Will be running 1 Kinetik HC1800 and 4 Kinetik HC600's as battery bank, as well as a high output alternator.
I designed my box for this build, 18 ft^3 net, tuned to 29 hz. Gonna be a C pillar wall.
Box is double layered birch all around. 1.5" thick everywhere you look
That's where I'm at right now. I've still got a lot ahead of me, and will be updating this log as I continue.
Any feedback? I've simplified 3 years of previous work and crunched everything into 1 post and have probly forgotten tons of stuff...so if you have any questions about anything ask away.
Old 01-23-2014, 05:35 PM
vince79vette's Avatar
0/11 sssss2011
Looks good man. When u run ur wires I would use these grommets
I have a 91 Cherokee with a welded in 6th order and there is no way u could run a lot of wire threw the firewall. I have 6 runs back. Also do a run back for neg because our jeeps rust like no other in a heart beat lol I saw better voltage with just 1 one back. And also have u looked at the adj voltage module. Very easy to install and let's us charge at what ever voltage we want. I think at lease up to like 20v but highest I would go in ours is 17v because our wiring can't take over that. I charge at 15.8-16.2 and everything is fine I have been running that high for years. Just don't use reg battery's or optimas as it will kill them after a year or 2
Old 01-23-2014, 05:36 PM
0/11 ssssss543
Just a slide in box or you building a frame to seal it off. Any comparison on previous setups? numbers?
Old 01-23-2014, 05:39 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Hell yeah. Looks like nice time progression. Never seen a popcorn fix amp. Dig it man keep up the pix!
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 01-23-2014, 05:46 PM
0/11 sssssss56
Thanks man...I havent messed with the voltage module yet and charge at 14.2 v usually. And I will be using 4 Kinetik HC600's and 1 Kinetik HC1800 for batteries...so dry cell car audio batteries all around.
I'ts just a slide in wall, and then I will be building beauty panels and sealing it off with expanding foam. This is my first wall build so this seemed like the easiest way to build and should still perform great. And I have never metered any of my previous setups...Never been a numbers guy. I'd like to put this wall on the meter just to see what it does, but I don't have any high hopes for it haha. Its tuned to 29 hz...for groundpounding...def not for numbers
Old 01-23-2014, 05:55 PM
0/11 ssssss543
As long as its sealed well you should be ok. I've seen non sealed setups that did not impress (4-15's 5k c pillar only doing 146's
Old 01-23-2014, 08:06 PM
0/11 sssss2011
U defiantly need the adj voltage. Sounds like ur voltage module is going out. They ether charge really high like 16v or really low like high 13s. I love mine. When it's set it charges at that no matter what is going on. It's great. Prob the best upgrade I have done on the jeep. U will be amazed how much power u get at 15v
Old 01-23-2014, 08:12 PM
0/11 sssssss56
something like this?
External Voltage Regulator Kit for Chrysler Dodge Jeep Vehicle Alternator ECU Bypass
Old 01-24-2014, 12:48 AM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
I have an XJ as well but mine is older, its a 91.
Do the newer ones like his with the newer body style still use the PCM under the hood to regulate the alternator voltage? If they do, I would for sure go with an external regulator cause if your not having charging issues now, you will be.....
It's better to keep your mouth shut and give the impression that you're stupid, than to open it, and remove all doubt.
Mistakes are how you learn; try not to learn too much at any one time.
Old 01-24-2014, 07:07 AM
0/11 sssss2011
Yup that's it
First time welding a steel cage. Jeep Grand Cherokee c-pillar wall rebuild. AudiophilesEngineering Build Logs 26 02-26-2014 08:25 PM
Jeep Cherokee- Anyone louder using smaller subs, no wall? sxpimpin General Car Audio Discussion & Questions 0 08-06-2013 06:59 PM
340 Amp Mechman alternator for jeep grand cherokee 6.1L or 5.7L jeep commander Mnorwood01 Wiring, Electrical & Other Installation Equipment 16 12-29-2012 10:09 PM
95 jeep cherokee 4.0 full wall bwest5662 Car Audio Packages 37 10-16-2012 09:38 AM
c pillar wall in a jeep Hector_509 Enclosure Discussion & Design Construction Help 1 10-14-2012 10:30 AM
