Enclosure Build: Birch, kerfed, AB HD 12's - Car Audio Classifieds!
Old 01-28-2014, 07:16 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
Default Enclosure Build: Birch, kerfed, AB HD 12's
Another build for Wooferwarehouse.com, this one will be for a pair of 12" AB HD's. He's opted for birch and a kerfed port
Specs come to:
-3.16 cubic feet net
-32hz tuning
-42.25 sq inches of port area
A look at the design:
Got the pieces cut (top and bottom aren't in the pic)...
Curves in all the right places...
I just came upstairs to upload these while the compressor runs, I'll probably have to be getting a design worked on while I'm up here but I should have more pics up later, going to be putting the back, sides, and rear 45-inserts on tonight...that's the plan at least
Louder. Lower.
Team Tupperware
The Following User Says Thank You to Pioneer~Saturn For This Useful Post:
DirtyDonkey (01-28-2014)
Old 01-28-2014, 07:24 PM
IS300IAdeathRow's Avatar
0/11 sssss3693
Feedback Score: 42 reviews
damn man i love those kerfed ports what do you use to fill the cuts in the kerf, just wood putty or filler?
2013 Toyota Highlander
Build to come.....
Old 01-28-2014, 07:28 PM
0/11 sssss8346
Thanks and I don't fill them typically, I seal off the inside of the area with a 45 on the interior.
Louder. Lower.
Team Tupperware
DirtyDonkey's Avatar
0/11 ssssss351
Thanks P~S excited for this box!
The Following User Says Thank You to DirtyDonkey For This Useful Post:
Pioneer~Saturn (01-28-2014)
Old 01-28-2014, 07:59 PM
HOYT4X's Avatar
0/11 ssssss350
Those kerf boxes look awesome how well do they perform compared to a aero or a basic slot port
02 Zr2 S10
Singer 270 alt 1 run of 1/0 knuconcepts cca wire 2 black juice box in cab and a xs d3400 under hood
DC5k on a DD 818 in a 4.8 cube box tuned to 35hz powerbass 3xl comps in front doors and focal 1" silk dome tweeters in the a-pillars
Old 01-28-2014, 08:13 PM
0/11 sssss8346
Thanks and tbh it's mainly an aesthetic feature, especially when talking about real-world change. In certain situations you may be able to curve this-and-that and see a difference on the meter but when it comes to these daily boxes it's more style than anything. It does smooth airflow at the mouth of the port though, which is never a bad thing imo.
Louder. Lower.
Team Tupperware
Old 01-28-2014, 08:16 PM
HOYT4X's Avatar
0/11 ssssss350
I'm amazed at how ur boxes always come out so perfect and end up sounding amazing wish my boxes would come out like that
02 Zr2 S10
The Following User Says Thank You to HOYT4X For This Useful Post:
Old 01-28-2014, 08:56 PM
0/11 sssssss46
Very nice work man.
The Following User Says Thank You to fukaz28 For This Useful Post:
Pioneer~Saturn (01-29-2014)
Old 01-29-2014, 07:19 PM
0/11 sssss8346
Little more...
Terminal cup hole cutout and rounded over on the interior...
With a hint of warp'age in the panel it wasn't as square as I'd like...so I makez it square...
More later
Louder. Lower.
Team Tupperware
DirtyDonkey (01-29-2014)
Old 01-29-2014, 07:22 PM
0/11 ssssss351
Looking good!
Enclosure Build: SA-12, kerfed port Pioneer~Saturn Build Logs 23 01-29-2014 11:25 PM
Enclosure Build: Kerfed single 12, bedlined, birch :) Pioneer~Saturn Build Logs 46 11-04-2013 09:56 PM
Enclosure Build: kerfed ports, dual 12's Pioneer~Saturn Build Logs 19 07-31-2009 11:11 AM
Kerfed Port Enclosure Build For My Hdc315 twisted Build Logs 15 04-12-2009 12:06 PM
Kerfed Enclosure Build for 10" Solo-X Pioneer~Saturn Build Logs 11 03-06-2009 01:10 PM
