Next Woofer Build- PROJECT MMAG - Car Audio Classifieds!
Old 01-29-2014, 05:48 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Default Next Woofer Build- PROJECT MMAG
My first "real sub" ... a Cerwin Vega stroker 152.. lost its fight against power around 2007...sad day when I accidently plugged it into the wall
So she's been sitting, sad and lonely... about a month ago I pulled the magnets off to give it a touch of unique. Then decide to put it up FS... hasn't sold sooo.... its getting build into a sq oriented woofer, low power around 700 to 1000 rms. The coil from a diff sub is being reused and the motors parameters will not be the same as stock (not in a bad way).
this magnet arrangement was not modeled, nor is its "perfect". It will suit its goals however and I see no issue in the outcome not being fully successful.
Here's what details I know;
-it will use a 15" 12 spoke basket
-single medium spider
-single lead
-a copper coil that's had 2 layers stripped, so its a 2 layer single 2 ohm
-terminals, no direct leads
- it will be a split gap
-motor will be custom built, 1 of a kind
- the motor has never been reused before, ever
-the dustcap will be plain jane to start
-motor will be custom painted
-basket will be custom painted
Parts list/ordered;
-cone
-spider with leads
-65 (yes 65) c8 ferrite magnet block for the bottom gap, not rings
-32 c8 ceramic disks for the top gap
-gasket
-terminals
Stay tuned
Old 01-29-2014, 08:03 PM
Authorized Vendor
0/11 ssss14115
The recycled coil. Was originally a dual 2, 4 layer round copper
Its now a single 2, 2 layer
^what happens when you find a silver sharpie^
Now, although it may look "ugly" , its 100% functional and didn't cost me $45. If this was a TI basket build, id be worried about looks but you wont see any of the former unless you look through the cooling holes on the basket. Although, it will be cleaned up a little once the whole assembly is glued together.
Old 01-29-2014, 08:23 PM
hawaiianmaxx's Avatar
0/11 ssssss862
Could you explain what's going on with the two red strips?
KIDS SAY THE DARNDEST THINGS-
STOP PAYING ATTENTION TO YOUR RATIO IN 4TH ORDERS!!!! Ratios in 4th orders mean about as much of the color of socks you wear.
I never said getting 60 MUSICALLY will be easy did I? Getting 60+ on a burp machine is, sorry to say that but it is.
Old 01-29-2014, 08:29 PM
Authorized Vendor
0/11 ssss14115
Strips of heat shrink, just using it as an insulator
Old 01-29-2014, 08:32 PM
Authorized Vendor
0/11 ssss14115
This is very similar to the technology/topology this subwoofer motor uses
the winding height matches top of motor to bottom of the lowest plate... no matter which way the coil goes, the winding are always in one of the gaps
Old 01-29-2014, 08:38 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Umm.....how the hell do you accidently plug a sub into a wall outlet?
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
The Following User Says Thank You to Boomintahoe For This Useful Post:
Old 01-29-2014, 08:41 PM
Authorized Vendor
0/11 ssss14115
I was kidding...I replaced it with an sp4 so I walled it...did well till u plugged the vent
Old 01-29-2014, 08:43 PM
0/11 ssss12531
Oh ok! I guess wall outlets put out what...3000 watts? or whathaveya.
Some kind of equasion to figure it out.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 01-29-2014, 09:26 PM
Authorized Vendor
0/11 ssss14115
The 12 spoke basket will be custom fitted for this motor .. to start, I've got to clean the bolt holes so I can make a mark though them onto the basket
place the plate on top, center and make sure its not to close to the basket factory holes
Sharpie wasn't long enough to reach the basket so creativity = activate
paint
Q tip
Mark through the top plate a nice paint dot
Drill the dots
check that its centered. Good
(Looks off center, but it is not)
Old 01-31-2014, 11:43 AM
Authorized Vendor
0/11 ssss14115
Got a bunch of goodies in today
First up, top gap magnets
Next a few bottom gap magnets
To my amazement "ultra" let me order a spider with leads
Terminals... I like this kind and they we're cheaper
Still waiting on the cone and I have alot of work to do to start assembling the motor
DC Build!! (still a working project) newarkbeast973 Build Logs 92 03-01-2013 12:16 PM
Project DC , 2001 Suburban build.. TwistedMinds General Car Audio Discussion & Questions 48 08-22-2010 07:17 PM
New build: Project Shocker! DB Drive - DC Audio cthedinger Build Logs 63 08-11-2010 02:51 PM
My first fiberglass project. Will be a build log eventually. ghostmechanic Build Logs 7 06-18-2009 03:42 AM
Thumper's Build Project xpl Build Logs 14 03-21-2009 02:11 PM
