The ISUZU LECHONA C pillar wall build log - Car Audio Classifieds!
Old 02-09-2014, 06:18 PM
regizzle's Avatar
0/11 sssss1427
Default The ISUZU LECHONA C pillar wall build log
WELP, this has been a long time coming. Through countless builds and countless different setups and i am finally gonna try to keep track of one that i want to be proud of.
Harmless plugs are harmless:
BHE designs
Supreme Customs Garage
Singer Alternators
Tantric Sounds
Epicenter Jon for doors
Crescendo Audio
Power Circles Designs because Dre will inevitably be working on my truck
"F for Florida, F for Family, F for FloridaSPL" - Yes *****es, i just trademarked that ****.
in before F for ***g0t
First things first, equipment...
2002 Isuzu rodeo
4 12" Tantric HD/HDD's (up in the air based on box requirements but i havent spent too much time researching)
320 amp Singer (only 320 amp for this car on the planet, GET JEALOUS DENNIS)
Pioneer DEH-80prs
Crescendo PWX 6.5's
Crescendo RTS-1 (with FT1 Crossovers)
Crescendo FT1's
Crescendo Symphony or C1100's
XS power D3400
XS power D3100's
Ampre Audio 3800
Sundown Zv4 15"
Knu Konceptz RCAS
XS power OFC/CCA
Tons of sex.
BHE design from robin.
Birch and aeros.
This will be a nendo, tantric, xs power and one other local company build.
Tried to keep it all Florida but i have a bit of loyalty to Murphy as well as Mr.Singer... Louisiana ain't that far away anyhow and Singer has my heart so its ok.
will buy my 4 Tantric HDD's eventually.
Substage is temporary til i have funds for wall and some components of the Front stage are temporary and now... so is amp, friends are cool. :eyebrow:
I plan on getting some HID's soon as well and changing the antenna. I have a hard on for that little antenna, like, the one thats half the general sized one? i think it would look good on the truck. Anyway, ON TO PICTURES!
Also, i will be doing the tints as soon as i change the insurance to my name, perhaps sooner. Tints will be done by Haim at his shop Supreme Customs Garage, great guy and great work, Great friend as well. Also, considering the love of my life has lupus, i am lucky enough to be able to put my vehicle under the EXEMPT list for tints... in other words, any tints i want, as dark as i want on all windows but windshield.
some equipment:
Front amp:
Secondary amp for rear of car came basically free sooooo lol:
Bassaholics crew:
i made an honest mistake. I apologize.
Old 02-09-2014, 06:19 PM
regizzle's Avatar
0/11 sssss1427
Let building commence:
Dash was relatively easy to remove.... because i didnt have to remove it. Honestly, it was the fastest install i've ever had to do. Granted it took a while seeing as i was setting up the as much as the car as i could for future equipment... but it was fast! i got a feel for removing the panels and such so when i go to do my doors, it should be fairly fast... on to radio install.
because you need a better ground, we all know that.
As it seems, someone liked sparkles who previously owned this car... that or i was a drag queen one night and didn't know... or maybe thats what i want you to think. :eyebrow:
So, popping off the side skirts (if thats what you would call them, i found there was basically no space in the alloted, i guess you can call channel? so i basically put that ish past that on the floor, went smoothly.
So while my little bro was helping me pass the cables to the back, i decided to pop the door speaker pods off. Upon taking off the grills, it looked like it was gonna be the easiest install ever. After further examination, i figured i had to dremmel out some of the plastic to fit my nendo speakers because frankly, they didn't fit at all couldn't even get past the basket... UPON FURTHER INVESTIGATION, My brother in law put the window down as i was explaining to him my dilemma.... i just about gasped at this point... NO CLEARANCE WHAT SO EVER. Little over 2 inches... i mean, there is SOOOO much space behind the window guide and it all goes to waste. all of it. made me rage a little, but gave me slight reinforcement to the realization that i need to do my doors, wheres jon?
So, i went back to installing the radio and we cut out a bit of the plastic to fit the mic and USB through.
and then hooked up mah RCAS:
and put er in....
Next,
Since my 320 amp alt, from singer alternators, mikes a great guy, this isnt a plug at all.... great alternators, you should buy one. Since my 320 amp alt is a 1 wire alt, i need to wire it to an ignition source. Pulled out my handy dandy test light to find the power on one of my cigarette lighters considering brown and black arent the most telling of signs... i mean brown can be ground ya know?
Brown was positive... -_-" so i cut her up and fit some 16gauge wire on one side. My girlfriend then wrapped that wire with electrical tape slowly... by hand.. so that i could pass it through above the transmission as i have a rubber boot by my shifter that seals off the transmission area from my cab. Just gonna poke a hole through there and feed the wire down and under the truck to the alternator. Now instead of having a mess of wire, i decided i was gonna play it smart and i wrapped the wire up and put my little pocket back in place. Now when i go install my alternator, its as easy as just opening that pocket, passing that wire and done.... and then finding someone to latch it on that isnt a furnace. no biggie.
Popped my console back on and then sold my ZV4 to the guy that was coming over, fought with my beautiful girlfriend, and then started playing with it :eyebrow:
At this point, i did my time alignment and such... cool little process but takes a little time for it to process each speaker and find its right power level and such. cool beans for sure tho. any who, finished product:
That's all for today. I mean i passed my RCA's, my volt meter positive, my remote wire, my alternator wire, diagnosed my doors, paired up my phone for Bluetooth (which was a hassle because the menu sucks), installed my radio and tomorrow I'm changing her oil and installing my D3400 up front.
Waiting on robin to get a design to me and to order my wire. Went with robin for a design on my zv4 box because although I know me, Zaim and Dre could put it together and make something great, I would like to incorporate as much of Florida as i can, i am a very strong believer in supporting family and you guys are my family in one way or another, so if i can spread the love and wealth to family in whatever way i can, i will do so even if its not a ton of money. For us regular folk, every dollar counts.
Thanks for checking it out and i hope to have more for you guys soon!
Bassaholics crew:
Old 02-09-2014, 06:20 PM
regizzle's Avatar
0/11 sssss1427
Did my oil change, put in my D3400 up front, and removed my splash guard under the car to prep for my alt install and as you can tell, yes the original posts were copied from floridaspl.
Bassaholics crew:
Old 02-09-2014, 08:56 PM
BassikInstincts's Avatar
Ω rise is way too high..
0/11 sssss3784
Nice work, you now have my curiousity.
06 Chevy Malibu Maxx LT
empty trunk
DC Power 270xp
.... so far
Old 02-09-2014, 11:50 PM
EpicenterDesigns's Avatar
Loyal Member
0/11 sssss1862
Drag Queen at night huh?
The bitter after-taste of a poor quality job will last far longer than
the sweetness of that cheap price!
Old 02-09-2014, 11:54 PM
regizzle's Avatar
0/11 sssss1427
lmao, might have to do my doors jon, these nendos no fito
Bassaholics crew:
Old 02-09-2014, 11:55 PM
murphy's Avatar
0/11 sssss1743
I thought he was a gigolo..........like deuce....lol
CEO TANTRIC SOUNDS
world class transducers
The Following User Says Thank You to murphy For This Useful Post:
regizzle (02-10-2014)
Old 02-09-2014, 11:57 PM
regizzle's Avatar
0/11 sssss1427
"THATS A BIG BITCH."
Bassaholics crew:
Old 02-10-2014, 12:01 AM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Tuned in..
Sent From Oklahoma
Old 02-10-2014, 12:56 AM
Loyal Member
0/11 sssss1862
I look at your door panels and see so much room for activities.
No issues.
c pillar wall in a jeep Hector_509 Enclosure Discussion & Design Construction Help 1 10-14-2012 11:30 AM
Bumpin Dodge's 2003 Ram Build Log 4 lvl4 15s crescendo 3k wall Bumpin Dodge Build Logs 178 06-16-2012 11:39 PM
Jacob's Wall Build Log sundownz (Sundown Audio) 114 07-12-2011 07:08 PM
wall behind the c pillar? JEXTEL General Car Audio Discussion & Questions 21 12-12-2010 04:40 PM
Frontier kinda wall, 2 AQ SDC 15's build log Goindef154 Build Logs 26 07-06-2009 02:40 AM
