Enclosure Build: Angled and kerfed port..swag - Car Audio Classifieds!
Old 02-13-2014, 09:05 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
Default Enclosure Build: Angled and kerfed port..swag
Alright guys, this one will be a bit different with an angled and kerfed port...
(This will be for a Sundown SD-10)
Specs come to:
-1.15 cubic feet net
-33.5hz tuning
-14.79 sq inches of port area
The design...
Got the port panel kerf-cut and 45-deg insert glued and nailed. I'm going to let the glue cure before moving on to angling this, it will need to be solid for the next step...
More when it happens...
Louder. Lower.
Team Tupperware
The Following User Says Thank You to Pioneer~Saturn For This Useful Post:
airtrade (02-19-2014)
Old 02-13-2014, 09:10 PM
0/11 sssss2095
When it happens, I would like to see more
Old 02-17-2014, 05:40 PM
0/11 sssss8346
Got the cutout done, rounded over, baffle mounted and angle partially done on the port panel...I'll need to pull a maneuver to finish the angle, will need to run by the store to get something for it though...should be pretty slick once done.
Doesn't look like much but I spent a good bit of time planning everything on this one
Possibly more later
Louder. Lower.
Team Tupperware
Old 02-17-2014, 06:01 PM
IS300IAdeathRow's Avatar
0/11 sssss3693
Feedback Score: 42 reviews
Good stuff as always bro, very nice work!
2013 Toyota Highlander
Build to come.....
The Following User Says Thank You to IS300IAdeathRow For This Useful Post:
Pioneer~Saturn (02-17-2014)
Old 02-18-2014, 07:16 PM
0/11 sssss8346
He's done it again...*oops*
Can you keep up?
Panels arent mounted yet, just a mock-up and the other side panel on the far end will be routed to size once everything's mounted...more when it happens
Louder. Lower.
Team Tupperware
Old 02-18-2014, 09:49 PM
0/11 sssss2095
Nice, nice work man.
Old 02-18-2014, 09:55 PM
doug118's Avatar
0/11 sssss4674
Ouuu lala
Old 02-19-2014, 06:34 AM
0/11 sssssss50
Dougie Fresh, very nice sir!
Old 02-19-2014, 11:04 AM
0/11 sssssss18
NICE!
Old 02-19-2014, 11:16 AM
0/11 ssssss266
very nice work.
watchin
mentally unstable but otherwise just messed up.....wooohoooo
Good luck on your journey
take care and have fun
Enclosure Build: SA-12, kerfed port Pioneer~Saturn Build Logs 23 01-29-2014 10:25 PM
Enclosure Build: 2 12" HDC4's, kerfed, angled, next level. Pioneer~Saturn Build Logs 50 01-10-2014 09:20 PM
Enclosure Build: Banks' DC 12", kerfed port Pioneer~Saturn Build Logs 33 05-21-2012 04:47 PM
Enclosure Build: Bobby32's DD9512, kerfed port Pioneer~Saturn Build Logs 15 10-22-2009 12:11 AM
Kerfed Port Enclosure Build For My Hdc315 twisted Build Logs 15 04-12-2009 11:06 AM
