The Build before the Build - Car Audio Classifieds!
Old 02-28-2014, 09:47 PM
joebobclark's Avatar
Your Moms New Boyfriend
0/11 ssssss985
Feedback Score: 22 reviews
Default The Build before the Build
Thought I would share some pics of my subwoofer build, before I get started with my Blazer build...
So, about 6 months ago, I was cruisin the local craigslist ads when I saw an ad that I thought for sure was a typo... 12" Adire Audio Brahma, $20. Said it was blown, but still.... REALLY? So I contacted the seller, and it was true! Picked it up immediately!
It sat on my bench for a few months while I considered selling it or trying to find a match. No simple task, as I wasn't even sure which model motor I had. Narrowed it down to a MK1 motor and was lucky enough to have a match show up for sale over on CA.com! It was a working 12" so I had to pay up to get it, and I wasn't sure how I was going cut up a perfectly good sub of this caliber! USPS helped me that, lol, by making sure it wasn't working when it got to me... Broken basket.
Some pics of the 2 together, and the damage to the second...
So, I had 2 Brahma MK1 motors and was ready to build a pair of 15's!
Contacted Jacob at Sundown to see if he had any QC used, newly tooled baskets with the 10" spider landing. He was very helpful, as usual! Gave me great deal on a pair of used baskets. I don't mind cleaning them, as I plan to paint the baskets, so I would have hated to ruin 2 brand new ones scuffing and painting them anyways...
2005 S10 Blazer 2-door
**** Under Construction****
Old 02-28-2014, 09:48 PM
0/11 ssssss985
I bought the Sundown vented spacers, but after talking to Dave over at PSI (he built most of the original Brahmas BTW... very knowledgeable!) he suggested not using the spacers. Couldn't make the coils he had work with the XBL2 motor and the spacer. But he did suggest venting the basket! So I did...
Put some primer on one... Kinda like the white on the basket! But they will be Metalcast Blue when complete...
Dave at PSI and I talked about what would work and would be best for what I wanted. He built me a drop in recone... custom UNwound 3" 8 layer flat wound coils, Dual 1 ohm. Non pressed paper cone, high roll surround. Single medium 10" spider with hand sewn leads. Went with the dished CF dustcaps, for looks and weight. Should be long throwing, lightweight, low Fs... and sexy as hell!
Should be able to work on them more tomorrow, will continue to add pictures until they are complete! Then on to the Blazer to see how these bad boys get down!!!!
The Following User Says Thank You to joebobclark For This Useful Post:
iamsonic (04-01-2014)
Old 02-28-2014, 10:03 PM
BKNIGHTS's Avatar
0/11 sssss2949
Feedback Score: 61 reviews
Nice! the sundown basket made the motor look tiny lol. Tuned in.
The Following User Says Thank You to BKNIGHTS For This Useful Post:
joebobclark (03-01-2014)
Old 03-01-2014, 01:57 AM
Inferno333's Avatar
0/11 sssss3845
Feedback Score: 44 reviews
Gorgeous drivers bud!
The Following User Says Thank You to Inferno333 For This Useful Post:
Old 03-01-2014, 02:09 AM
BKNIGHTS's Avatar
0/11 sssss2949
How many mm of excursion before the coil leaves the gap?
Old 03-01-2014, 03:18 AM
serjr711's Avatar
0/11 sssss2699
Feedback Score: 65 reviews
What kind of primer did you use?
Old 03-01-2014, 04:39 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
What imp are the coils now that they have been partially unwound?
Current Build:
#60sHereIcome
Old 03-01-2014, 11:22 AM
0/11 ssssss985
Good question..... I hope they wont, lol. But it is something I will keep an eye on. Dave didnt say anything about it, so I assume they wont...
Old 03-01-2014, 11:24 AM
0/11 ssssss985
Its cheap high build primer from Home Depot, .98 cents a can IIRC.
Old 03-01-2014, 11:27 AM
0/11 ssssss985
1 ohm after unwound. They were higher imp, higher RMS coils that Dave unwound. He said they would come out .75-1 ohm, they came in right at 1. He said they would be good for 1000-1200w RMS after unwound, which is right where I want to run them, SS Rubicon 2500.1 for the pair.
91' CRX Daily Driver Build - Taylorpro's 2013 Build taylorpro Build Logs 136 07-06-2013 10:57 PM
2 18" Fourth Order build this weekend-Tips before build sxpimpin Enclosure Discussion & Design Construction Help 10 03-15-2012 09:13 PM
temporary budget build...94 xcab ranger (work truck build) CodyBrown2013 General Car Audio Discussion & Questions 8 02-17-2012 10:44 PM
SPL_II's Team CACO Build Log <--- First real Build! SPL_II Build Logs 123 09-23-2010 09:44 PM
deepsilencer's new box build video designed by james(A.I),build by 99s10walled deepsilencer Car Audio Videos 1 08-30-2010 02:43 AM
