Small build for my Son - Car Audio Classifieds!
Old 04-07-2014, 05:42 PM
Cablguy184's Avatar
0/11 ssssss249
Default Small build for my Son
This is my Son's (Dylan) 1988 Ford F150 ...
Simple build ... 6.5" component set with a pair of 10s.
Randal Johnson ... Comcast Xfinity ... 1949 Ford Tudor Sedan ... Team Linear Power / Hyper Lights
Old 04-07-2014, 05:45 PM
HOYT4X's Avatar
0/11 ssssss350
knowing you its gonna be a very clean looking and clean sounding build tuned in cant wait to see sum progress
02 Zr2 S10
Singer 270 alt 1 run of 1/0 knuconcepts cca wire 2 black juice box in cab and a xs d3400 under hood
DC5k on a DD 818 in a 4.8 cube box tuned to 35hz powerbass 3xl comps in front doors and focal 1" silk dome tweeters in the a-pillars
The Following User Says Thank You to HOYT4X For This Useful Post:
Cablguy184 (04-07-2014)
Old 04-07-2014, 05:49 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Yeah, cableguy builds, these were very well thought out and constructed in the old days.
I feel this will follow the pattern, any phase linear going in?
Old 04-07-2014, 05:53 PM
Cablguy184's Avatar
0/11 ssssss249
For now, we are using Focal Amplifiers in this one. Sponsored by Hyper Lights.
Old 04-07-2014, 05:54 PM
Cablguy184's Avatar
0/11 ssssss249
Thank you Sir !!! More pics on the way.
Old 04-07-2014, 06:02 PM
Cablguy184's Avatar
0/11 ssssss249
RD Audio tweeters up on the A-Pillars and Blues Car Audio 6.5" drivers in the Doors ...
More work def. needs to be done, but its a great starting point for test and tune ...
Old 04-07-2014, 06:19 PM
HOYT4X's Avatar
0/11 ssssss350
looks awesome u gonna change the placement on the 6,5s instead of bein behind the door to bein in a pod on the outside of the door panel
02 Zr2 S10
Old 04-07-2014, 06:38 PM
Cablguy184's Avatar
0/11 ssssss249
I need to go back and read the rules of MECA. If my son decides to compete with this truck, we plan to put it in "Stock" class. Meaning that the door pannels (and all of the other pannels for that mater) will remain Stock. Not sure what to do with the tweeters though ...
... But for a single cab truck, sounds dang good for what it is ...
Old 04-09-2014, 06:24 AM
Cablguy184's Avatar
0/11 ssssss249
not finished yet, but a good start ... Pair of 10s sealed behind the seat.
Old 04-09-2014, 08:03 AM
0/11 sssss2148
Feedback Score: 26 reviews
Clean and simple, works well with the overall look of the truck as well....very nice.
small re-build BallzFast Miscellaneous Build Logs 1 04-15-2013 09:54 AM
small SQ build rdlyn13000 (Sundown Audio) 2 01-07-2013 05:17 PM
Small Boombox Build 813thumper Miscellaneous Build Logs 2 02-04-2012 11:09 PM
Small bass package for power wheels build or small daily setup jjffy6 Car Audio Packages 10 10-10-2011 12:08 PM
