Swifts F250 flat wall with 4 DSS Ethos 18's - Car Audio Classifieds!
Old 06-28-2014, 11:19 PM
SWIFT's Avatar
0/11 ssssss656
Default Swifts F250 flat wall with 4 DSS Ethos 18's
Figured I would start a build log. My 2012 F250 daily work truck is gonna attempt to get loud and low here.
21cu tuned at 31hz. Gonna run a Ampere Audio 7500 and repping Team DSS with 4 Ethos 18's. Second amp to follow
All 2/0 with 8 group 31's, buss bars and HO Alt.
Crescendo 1100.4 and Pro Audio gear in doors I will do. Gonna be competing Meca headrest and planing to be competive at a lower Hz than most do. We'll see. Pics to follow
Here is the truck that is fixing to get its ass whipped
2012 F250 Lariat, lifted on 22's and 35's
4 DSS Ethos 18's flat wall, 2 Ampere Audio 7500.1's
Mechman 370, 9 batteries, Rockford Punch Pro front
Team DSS / Team Ampere Audio
The Following User Says Thank You to SWIFT For This Useful Post:
massivespl (06-28-2014)
Old 06-28-2014, 11:34 PM
EpicenterDesigns's Avatar
Loyal Member
0/11 sssss1862
Is this a new truck than the last you you built in?
The bitter after-taste of a poor quality job will last far longer than
the sweetness of that cheap price!
Old 06-29-2014, 02:02 AM
SWIFT's Avatar
0/11 ssssss656
Yeah the last was a 07. The doors looked great you did too.
EpicenterDesigns (07-02-2014)
Old 07-02-2014, 10:53 AM
Loyal Member
0/11 sssss1862
Awesome. Now get on with the pics. You know we love the pics around here.
Old 07-02-2014, 11:26 AM
0/11 sssss1393
Will this be at finals? Love to finally hear these ethos
Old 07-02-2014, 11:56 AM
SWIFT's Avatar
0/11 ssssss656
It will be, whether I make it in or not, I will attend. I have zero points this year and have to try to make as many events as possible. My teammate will also be there with his 6 Ethos 15's, it gets down aswell
Old 07-02-2014, 06:38 PM
massivespl's Avatar
0/11 sssss8409
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 07-14-2014, 09:23 AM
SWIFT's Avatar
0/11 ssssss656
Here is the shell that is being used from my old setup, based on Kippel results these subs model well in this enclosure. Port area could be increased but should still get the job done and sound great seeing as that I'm tuned low.
Over 200ft of 2/0 will end up in the truck
Got here all emptied and back windows plastic dipped
Cutting holes for power and ground coming from tool box. Power on drivers side, grounds on pass side
Dayum what a Beast!!
Here is the old shell cut and modified to fit 4 18's.
New baffle mock up
Some bracing since its only 2 boards thick, but there will also be dowel bracing on the baffle as well.
More 2/0 cut and ready
Had to remove the door again and the wall/box is in place. The baffles had to be added after it was in so its officially not coming out of this truck without be cut up.
Baffles on and braced, its strong and shouldnt have any issues.
I have more pics but yall get the idea
Old 07-14-2014, 09:27 AM
onebadmonte's Avatar
0/11 sssss1221
Nice work salvaging the old box, sign of a true craftsman. Looking forward to your impressions and what numbers this built might throw up.
The Following 2 Users Say Thank You to onebadmonte For This Useful Post:
sthrnbumpn (07-30-2014), tc300 (08-05-2014)
Old 07-14-2014, 10:27 AM
SWIFT's Avatar
0/11 ssssss656
Thanks, the goal on the single amp is 155's or better at the headrest, when the second amp goes in I will be looking for maybe 58's headrest, 60 kick. Thats with this low tuned setup, all numbers I am looking for are below 40hz. I want a true ground pounder and will build much more for numbers in a minivan I have sitting here ready to get used.
Here is a sample of what kinda hurt its putting on the truck. These subs are brand new out of the box and just installed.
DSS Ethos 18's first play after install - YouTube
6 DSS Ethos Insane 4th order 16,000 watts Sencheezy Car Audio Videos 0 06-25-2014 03:07 AM
4th order wall or flat wall Dirtbikerrob Enclosure Discussion & Design Construction Help 9 03-05-2013 09:25 PM
07 Harley F250 and two FI 18's (pic heavy) SWIFT Build Logs 29 06-15-2012 09:15 PM
wall or no wall, scion xb, Obsidian audio 18's 98Expo Enclosure Discussion & Design Construction Help 20 06-07-2012 10:48 AM
wall for 96 f250 Question michael707 Enclosure Discussion & Design Construction Help 0 03-29-2010 03:15 PM
